Battery not charging
Old Oct 28, 2013 | 10:43 PM
nash220's Avatar
nash220
Cruising
Default Battery not charging
Went for the first test drive in my 81 after installing a new cam, lifters and push rods. Ended up having to get jump started when I stopped for fuel. It has a new battery and volt gauge shows 13 -14 volts. Any ideas where to start looking?
Old Oct 28, 2013 | 11:06 PM
SIXFOOTER's Avatar
SIXFOOTER
you may have left off a wire, there is a #14 running from the alternator directly to the battery that is the charge wire. Check your voltage at the battery with it running
Old Oct 29, 2013 | 12:21 AM
nash220's Avatar
nash220
Cruising
Checked all connections at alternator, they looked good. I will check voltage at battery in the morning.
Old Oct 29, 2013 | 06:03 AM
dpw21562's Avatar
dpw21562
Default Not charging
You may have a lost ground, that happened to me.
Old Oct 29, 2013 | 10:00 AM
lvmyvt76's Avatar
lvmyvt76
using a meter, check voltage coming out of alt, should be 14.2 volts, also at battery. Battery may be run down, use a charge to charge battery then check for voltage, 12+ volts there, if not have the battery checked for amps.(it may have 12+volts but have a weak cell) Don't count on the car to charge a low battery very fast. Use a battery charger to do that.
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Check to see if your battery 12v or higher, Start the car and put your voltmeter across the battery terminals and it should be 14v or higher.
Old Oct 29, 2013 | 06:07 PM
nash220's Avatar
nash220
Cruising
Ok, charged the battery, checked 12V at battery. Started car and checked 14V at alternator and 14V at battery. Went for a test drive and when I returned home shut car off and tried to restart. Car restarted, but didn't crank over real strong like it did right after I charged battery. Battery is only about 3 weeks old. Next step is to take battery back to where I bought it and have it tested.
Old Oct 29, 2013 | 06:39 PM
hugie82's Avatar
hugie82
It's not unheard of to get a bad battery! It's been happening a lot lately... I had a Harley battery that was bad from day one and a red top optimum battery do the same thing after 3 months.
If you have an optimum battery with the glass mat 6 pack design, they have to be charged with high amperage if they go dead. Like 80-100 amp jump start charge until they start hissing and cooking.
Old Oct 29, 2013 | 08:52 PM
Ironcross's Avatar
Ironcross
clean up the grounds, especially the short {12-14} inches from the battery to the frame...the engines will seek a ground through the brake lines and also the shifter cable....normally the reason the cables corrode up and break
Old Nov 1, 2013 | 11:02 AM
nash220's Avatar
nash220
Cruising
Think I found the problem. Went to pull the battery out to have tested and found I didn't tighten the connections when I installed it. OOPS....
When I installed the new cam I double checked all nuts and bolts, guess I forgot to check the battery. Seems to work fine now. Thanks for all the help.
Old Nov 17, 2013 | 07:50 PM
nash220's Avatar
nash220
Cruising
UPDATE: Turns out it wasn't the loose connections after all. Still had issues, so I took the battery in to dealer and had it tested. It tested bad. Have had no issues with new battery.
To Battery not charging
