Oil Spots
Old Oct 28, 2013 | 11:12 PM
rootine4's Avatar
rootine4
Default Oil Spots
Just got home with my first Vette a couple of nights ago, a 1980 4 speed. My elation has been tempered by a little bit of concern regarding oil. I stopped to check oil levels before leaving on a 500 mile trip home. The dipstick read low so I added quart and a half. Added a further quart and a half before I got home to get oil up to almost full. I have checked it several times since and it is holding steady but I haven't driven it either. There is some spotting up near driver front tire and some towards back center of engine bay.
What might be causing the leaks?
How long does it take for the oil to settle into the pan?
Of course, the guy from whom I bought the car said he has had no leaks. I asked him if it used any oil and he said no. He drove the car on a 900 mile trip recently.
The exhaust was not excessively smokey or blue on start up.
Old Oct 29, 2013 | 10:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by rootine4
...What might be causing the leaks?...
First guess is valve cover gaskets.
...How long does it take for the oil to settle into the pan?...
No longer than it takes gravity to pull it down.
Old Oct 29, 2013 | 10:14 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
However, I would keep an eye on it. That seems like a lot of oil to add over a short period of time. Valve covers leaking at that rate will make a terrible mess on the engine and under the car. Perhaps it is using more oil than the previous owner suspected or disclosed.
Old Oct 29, 2013 | 11:35 AM
rootine4's Avatar
rootine4
https://www.corvetteforum.com/forums...milies/lol.gif
I was just wondering if an older car might take longer for the oil to settle.
Old Oct 29, 2013 | 11:38 AM
rootine4's Avatar
rootine4
Roger. Willco. I do not know where the oil filter is or if there was a seal at the back. The car had 12 500 original miles on it when I bought it. Was concerned that the seals may have dried out with such little use. Prev. owner said it hadn't leaked oil.
Old Oct 29, 2013 | 11:54 AM
Easy Mike's Avatar
Easy Mike
...I do not know where the oil filter is...
Time to find out. Have you read through the owner's manual?
Old Oct 29, 2013 | 12:22 PM
Una4dbl55's Avatar
Una4dbl55
My 80 use's a bit also,it sat the last several years and seems to be dry as well, no leaks but I'm sure it's blow by, I'm currently working on a set of 441 heads to throw on it with the new headers and dual exaust
My guess is with that few miles it hasn't been driven enough to keep it in prime shape.
Old Oct 29, 2013 | 12:48 PM
ezobens's Avatar
ezobens
Of course it didn't leak any oil- Sounds like there was no oil in it to leak!
Seriously, if the thing was 1 1/2 quarts down when you picked it up, I'm guessing you didn't check the oil before you bought it-
Another 1 1/2 quarts for a 500 mile trip sounds like a significant oil leak (or usage).
If it was leaking that badly, you'd have a BIG mess on the driveway/garage floor and on the underside of the car. If the valve covers were leaking that badly, you would have smelled that oil burning all the way home.
You may want to have the engine steam cleaned top and bottom, change the oil and filter and watch what happens. A 30+ YO car with only 12K miles most likely has gasket leakage as well as some internal leakage (valve, intake seals etc).
Old Oct 29, 2013 | 01:23 PM
v2racing's Avatar
v2racing
It doesn't take much oil leakage to make pretty big spots on the floor.
The seals, gaskets and valve guide seals can dry out from age and little usage. The engine and tranny in my 64 SS has less than 10,000 miles on them, but they were both built about 18 years ago. They both leave their mark where you park it now. The fluids don't need to be topped off that often, but the spots looks like it leaks a lot.
The amount of oil you are going through would make huge messes if it were all leaks!
Old Oct 29, 2013 | 01:52 PM
rootine4's Avatar
rootine4
Read the owner's manual but there is no mention of the oil filter location. They are such low cars it is hard to see underneath. I thought maybe there was a leak there. The only time I saw oil underneath the car on the way home was when we stopped for lunch (about 30 mikes).
Old Oct 29, 2013 | 02:11 PM
CaseyJones's Avatar
CaseyJones
Oil filter is on the driver's side rear of the engine block pointing straight down. You can barely see it if you look over the fender where the brake master cylinder sits down towards the ground near the exhaust pipe.
You might be best served by going to or finding a good friend/mechanic who can show you a few things about your car. You need to know certain things to be able to keep it in shape.
Go to your local chain auto parts store and get the Haynes manual for your car. They are not good references for many repairs but they have a lot of pictures and diagrams that would be helpful.
Good luck! The good folks here are always ready to help!
Old Oct 29, 2013 | 02:55 PM
bluedawg's Avatar
bluedawg
Id jack the car up and look under it. More than likely the rear main seal and valve covers have leaks. The valve covers will be evident with oil on the exhaust manifolds. The next thing would be to pull the plugs and look for carbon build up from oil ingestion into the combustion process, Don't know how many miles are on the vette, but 1.5 quarts in 500 miles seems like a lot and if you were burning it, Id figure it would be obvious with the James bond smoke screen that was being left. As others had said the oil filter is on the drivers side rear of the block. Good luck and congratulations on the purchase of your new mistress.
Old Oct 31, 2013 | 01:50 PM
rootine4's Avatar
rootine4
Okay, I have discovered that what I was seeing was coolant. Going to look into that. Oil has been holding steady the past few days while putting on about 40 - 50 miles. I am guessing that it is highway speed driving that is causing some head gasket leakage. There are about 13 050 miles on the original engine.
I live in a cold climate so the car is going into storage today (sob). I will check the radiator and bottom hose for leaks before saying goodbye to her and check for leakage periodically over the winter. Any other thoughts anyone?
Old Oct 31, 2013 | 01:59 PM
bluedawg's Avatar
bluedawg
Were do you live?
Old Oct 31, 2013 | 02:31 PM
ezobens's Avatar
ezobens
If you are storing the car and live in a cold climate (unheated storage), check the antifreeze to make sure it can withstand your coldest temps without freezing. Unless you know when the coolant was last replaced, you have no idea if you're gonna have other issues in the Spring (IE cracked block etc).
Even if you have a mild leak, make sure the coolant is good!
Old Nov 6, 2013 | 03:26 PM
rootine4's Avatar
rootine4
Saskatchewan Canada
Old Nov 7, 2013 | 12:33 AM
iokepakai's Avatar
iokepakai
Oil filter location:[IMG][/IMG]
Possible oil leak locations: valve covers,intake manifold rear & front,timing cover,fuel pump,rear main seal,oil pan gasket,head gasket,I have replaced all of these and have no oil leaks....Used to have major leaks before replacing..
Old Nov 7, 2013 | 01:01 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Like the members suggested....buy a repair manual for your car.
Clean the engine top and bottom at a local spray-it-yourself car wash...then drive the car about 10 minutes to dry off the water from washing the engine.
Learn how to change the valve cover gaskets and change them first.., You won't have to jack up/crawl under anything..It will be a good learning exercise and possibly will solve some of the problems with oil leaks.
To Oil Spots
