solenoid problem
Old Oct 30, 2013 | 05:35 PM
macsen2's Avatar
macsen2
3rd Gear
Default solenoid problem
My 1978 vette has a solenoid problem,when starting her first thing in the morning,the starter keeps running on,I can turn the key off and on continuously and this makes no difference the starter keeps on turning until it decides to stop its self...I then let it sit for a couple of minutes and it will generally start without a problem...thank god I have not got a weak heart.Someone suggested that I go to an expensive non lead acid battery which might not drop voltage....would this help ?Any others had a similar problem ? I don't have a great deal of car mechanical knowledge and would appreciate any input...Weather does not get cold here so not a winter problem .....Mac
Old Oct 31, 2013 | 10:58 AM
MelWff's Avatar
MelWff
The starter solenoid is sticking, replace it or the complete starter.
Old Oct 31, 2013 | 11:22 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Starter solenoids need max voltage to engage....your solenoid is gentting plenty of voltage...
Like the other member said...for some reason the solenoid plunger is sticking and causing the starter to stay engaged.
You could remove the solenoid and clean it internally....or just buy a new one and install it yourself.
Take a pic of the wiring connections before you disconnect anything though.
Old Oct 31, 2013 | 11:33 PM
macsen2's Avatar
macsen2
3rd Gear
Thanks guys....I will take a look and see how I go...will post result.....regards Mac
Old Nov 1, 2013 | 03:24 PM
dochorsepower's Avatar
dochorsepower
And buy a good quality starter and solenoid, not the cheapest rebuild you can find - or you will be chasing other starting problems.
Old Nov 1, 2013 | 05:38 PM
REELAV8R's Avatar
REELAV8R
Obvious that the starter is working fine. Save some $$ just replace the solenoid. Just make sure you have good connections when you put it back together. Ground is there, and hot straight from the battery is on the starter. Be sure to disconnect battery before diving in.
Old Nov 2, 2013 | 03:26 PM
lvmyvt76's Avatar
lvmyvt76
take all of it apart and rebuild the starter and solenoid, while you have it off. If the starter is working, just clean it internally and put brushes on it, paint it and you have a new starter. Take the solenoid apart and clean the contacts, make sure the spring is not broken and paint it, you have a new solenoid. If the starter is original, don't get rid of it for trade-in on a different starter. You are wasting money on a different starter if you have the original(just my $.03 worth). Alternators and starters are easy to take apart and rebuild for a lot less money than "rebuilt" ones you purchase and the original ones are a lot better than the Chinese ones you are buying now.
Old Nov 4, 2013 | 06:59 AM
macsen2's Avatar
macsen2
3rd Gear
Thanks guys,replaced end fitting on solenoid contacts had been welding themselves together...working great now...regards Mac
To solenoid problem
