Bolt on dual exhaust?
Old Nov 2, 2013 | 11:33 AM
BlackC3vette's Avatar
BlackC3vette
Default Bolt on dual exhaust?
1980, Hedman headers, 4 speed - the original transmission crossmember was swapped out for a dual exhaust.
So, is there a header back, bolt on exhaust system for the setup? I know I can piece one together or flatbed it to the muffler shop, but is there a system that I can bolt in that actually comes close to fitting? The existing mufflers are in very good shape. Can I buy mid pipes from an earlier year to go from the headers to my existing mufflers? If so, what year mid pipes and will it require new muffles?
If I can get a system that bolts on, I can get this thing back on the road sooner than the forever later!
Old Nov 2, 2013 | 03:30 PM
lvmyvt76's Avatar
lvmyvt76
just drive it to the muffler shop like I did mine, just don't make a lot of noise. But, picking the correct muffler shop is the big question. Talk to them, then ask what is included in the price they give you, some won't price anything until they see the car, then they should be crossed off the list. Don't always take the lowest price either, ask them what material will used, what clamps, what size pipe etc.
Old Nov 2, 2013 | 04:48 PM
BlackC3vette
If I get pulled over, can I tell the officer you said it was OK?
Just kidding, but if I do drive over and happen to get stopped, I am going to get a no inspection ticket for sure. I already spoke to a recommended shop, but I was really hoping I could take care of this with a bolt on in my garage. I still have to run the engine to break the cam in.
Old Nov 3, 2013 | 12:27 AM
drwet's Avatar
drwet
You can buy the dual exhaust system from Corvette Central. You will have to fab up the connection from the headers to the rest of the system, but it makes for a very nice system that fits just like the factory setup. There are a lot of little tweaks and bends in the factory system that are required to get the exhaust up tight under these cars that are so close to the ground. Very unlikely you will get the same kind of fit from a muffler shop.
If you can weld, my advice is to bolt on the dual exhaust and fab up your own connections to the headers from some mandrel bent tubing. If you can't do the welding then bolt up as much of the dual exhaust system as you can, and then take it to the muffler shop to have the final connections made.
Over the years I have driven a couple of vehicles to the muffler shop with open headers and never had a problem. If you're careful, the noise really isn't that bad.
Old Nov 3, 2013 | 01:55 PM
tfi racing's Avatar
tfi racing
Check with Corvette Central,I beleive they have front pipes for use with headers,should only need some slight tweaking to work with your mufflers and headers.However if you have a good hotrod/musclecar muffler shop nearby(they are getting hard to find in some areas),I would give them a visit.
Old Nov 3, 2013 | 02:02 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I have driven to the muffler shop maybe 3-4 times with open headers.
you really want to feather foot the throttle.
One time I had a cop start following me about a half block from the muffler shop, but he went away when he saw my car turn into the muffler shop. This was about 30 years ago, when i looked a lot younger, I doubt they would pay as much attention to an older guy.
Doug
Old Nov 3, 2013 | 10:03 PM
BlackC3vette
Doug
I guess this would be one of the benefits of getting older.
Old Nov 3, 2013 | 10:28 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
LOL......true!
What about your Avatar?
Here's my "other" vehicle....
Now......back to the dual exhausts..............
Old Nov 4, 2013 | 10:49 AM
AZDoug's Avatar
AZDoug
I have one too.
It has dual exhausts, with an H pipe.
I trailered it to the muffler shop because it was under construction and had no wiring harness at the time. Next stop was the body and paint palce, then after it came home, it got wiring.
I used 2.25" pipes, for the 327 motor in there. I would have preferred 2.5", but connecting the larger pipes to the shorty headers would have been a problem.
Long tube headers were loud enough, shorties would have been real obnoxious, driving it to a muffler shop
Old Nov 4, 2013 | 12:05 PM
Camivette's Avatar
Camivette
You can get a dual exhaust for the 80 from corvette central. Flex pipe will get you from your collector to the dual system. then drive to the muffler shop and have them replace the flex with solid pipe.
I just did this with my 78 but it had flex in the front and rear to start
Old Nov 4, 2013 | 01:59 PM
rafalc's Avatar
rafalc
Hedman sells extension pipes that connect the header collectors to the rest of the pipes. I have them on my setup, although they were about an inch short so I had to add more length. You will not find a plug and play system to go with headers, they are all different....
post #119:
http://forums.corvetteforum.com/c3-g...project-6.html
Old Nov 5, 2013 | 05:21 PM
BlackC3vette
Originally Posted by doorgunner
LOL......true!
The avatar - 33 Ford Pickup. About 25 years ago I dragged a rusted frame/cab back the house.
Old Nov 5, 2013 | 05:32 PM
BlackC3vette
I found a solution to the headers back system. A local Vette restorer sells a system with the mufflers, mid pipes, and front pipes that go up through the crossmember. I can either fabricate/weld the last connection to the headers myself or take it to the muffler shop. He didn't have system in stock, I had to order it.
To Bolt on dual exhaust?
