Jumping tach needle
Old Jul 6, 2002 | 08:56 PM
page62's Avatar
page62
Default Jumping tach needle
I was going down the freeway at 70 mph a few minutes ago, and I noticed the tach was at 3400 instead of 3200. Then suddenly it went back to normal. And it jumped up once, then it was OK.
This is an stock HEI ignition system with a regular tach. I'm guessing either ignition module or tachometer electronics (sticky needle maybe?).
Any guesses? :smash:
Old Jul 6, 2002 | 09:55 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: Jumping tach needle (page62)
My needle was rather bouncy, then it stuck at ~2500. Cable was hitting a stop inside the distributor gear/tach drive. I tested with power hand drill (needs to be run in reverse) to check. As I pushed in on the cable with drill, it either didn't register, or bounced. Tach now reads very steady, not bouncing way past rev point as it did.
Chuck
Just reread your post and see that you have electric tach. Never mind! :bb
Old Jul 6, 2002 | 10:19 PM
75 Hot One's Avatar
75 Hot One
Sounds like incipient Tach failure. Mine behaved the same way-erratic behaviour with no pattern. When I replaced the Tach, everything was fine. That was about 17 yrs ago. I understand that replacement Tachs are no longer available but replacement cards are.
Old Jul 6, 2002 | 10:47 PM
SLICKMAN's Avatar
SLICKMAN
Mine jumps around (about 200 to 300 rpm) when I get to around 4500rpm. Its electronic so, not sure what that would be.. Never gave it much thought but, I saw this post..
Old Jul 7, 2002 | 03:40 AM
Ben Taylor's Avatar
Ben Taylor
Could be a bad tach filter, but I wouldn't do anything unless it starts getting worse.
Old Jul 7, 2002 | 08:20 AM
bud snyder's Avatar
bud snyder
Try checking wire connection at dist, could be loose.
Old Jul 7, 2002 | 08:36 AM
Cooter Tech's Avatar
Cooter Tech
Default Re: Jumping tach needle (bud snyder)
On my 80, my tach was extremely erratic, bounced all over constantly. It wound up being the alternater. Sounds weird, but it fixed my tach bounce. The alternater was over charging. Roger L. Gibbbons
Old Jul 7, 2002 | 07:49 PM
av8vito's Avatar
av8vito
Page62,
Had similar problem on my '80. After sustained high speed driving, my tachometer would consistently indicate 300-500 RPM high. Pulled the tach and replaced the circuit board (available from any of the parts magazines). This fixed the problem immediately. Good chance to replace the light bulbs too.
Good Luck,
Tom
To Jumping tach needle
