Broken Intake Manifold Bolt
Old Jan 12, 2014 | 10:35 PM
bluedawg's Avatar
bluedawg
Originally Posted by PeteZO6
That looks like a bolt holding the manifold to the head. If so, remove the manifold. Try the candle wax method (melt candle wax around the bold) and remove the bolt. I would try (dare I say this) vice grips tightened VERY tight on the bolt and remove it.
This shouldn't be a big deal. Welding a nut on there at this point seems to complicate the situation. KISS - Keep It Simple S....d.
Pete
I was thinking vice grips also. If that don't work, a reverse pattern drill bit, once it binds it will spin the bolt free.
Edit: I see you got it out.....Nice!
Old Jan 13, 2014 | 03:09 PM
garygnu's Avatar
garygnu
if the intake is off ,you mite be able to put 2 nuts on whats left of the bolt .tighten the nuts together and try to remove it .it would be a good time to sand blast your intake and clear coat it .
Old Jan 13, 2014 | 03:30 PM
AboveTheLogic's Avatar
AboveTheLogic
Maybe its a good time to get those nice high flowing aftermarket heads that you have been dreaming about
Old Jan 13, 2014 | 04:15 PM
hugie82's Avatar
hugie82
You have a lot of bolt to weld onto and if you were going to pick a bolt to break, that would be the best one
I would avoid pulling the manifold just because you might end up with 3-4 more busted bolts when you're done but if you have the time, its got to be done sooner or later
