75 quadrjet
Old Nov 8, 2013 | 05:21 PM
petty44's Avatar
petty44
Default 75 quadrjet
anyone got pics of there stock 75 quadrajet, was wondering if there r 2 vacuum breaks on it, mine only has the front pull-off, the 75 service and overhaul manual shows 2, have carb issues as the secondary's r not opening. carb # 7045222,,,, butch
Old Nov 8, 2013 | 06:44 PM
'75's Avatar
'75
It should have the choke pull off on the right front and a vacuum break on the right rear.
Old Nov 8, 2013 | 06:53 PM
Shark Racer's Avatar
Shark Racer
How do you know the secondaries aren't opening?
Are you talking about the secondary throttle blades or the air valves?
Old Nov 8, 2013 | 07:07 PM
bpassmore's Avatar
bpassmore
Are you talking about the throttle plate valves or the upper air valves? If the lower, if the choke is not adjusted correctly or the rear dash pot and linkage is missing the lower tv will not open.
butch
Sorry Shark I'm a little slow.
To 75 quadrjet
