Toms 12 Bolt Diff Conversion
Old Nov 10, 2013 | 06:08 PM
Luke in SA's Avatar
Luke in SA
Default Toms 12 Bolt Diff Conversion
Down the track... Looking at maybe changing out my stock 3.08 rear for a 3.55 Toms 12 Bolt.
A few on this forum have already done this conversion.
Anyone like to give a 'Rough' guide on full cost of change over ?
I'm talking from wheel-to-wheel. The whole lot. Car is a 68.
Cheers.
Old Nov 10, 2013 | 06:13 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Until they get the new case developed that they've been working on forever...the highest you're going to get is 3.73's with all 12 bolt guts.
There's a "Super 10" version that does some mixing and matching and does very well unless you have insane power and traction.
CK with Mike...Traccdog here on the Forum.
JIM
Old Nov 11, 2013 | 09:35 AM
tracdogg2's Avatar
tracdogg2
Like Jim said the tallest gear you can get is 3.73 in the 12 bolt. The Super 10 can be built with any ratio. The main difference between the two is carrier strength. Being down under, replacement parts and shipping expense also needs to be factored in. Spending more up front can end up costing less in the long run.
There are so many options it's hard to give even a rough estimate. 1480 u-joints cost more up front but will last much longer than 1350's. Stock or offset traing arms? Which brand? I'll send you a pm with my info so we can discuss this in detail.
Mike
Old Nov 11, 2013 | 12:49 PM
Solid LT1's Avatar
Solid LT1
Figure well North of $3500 for this type of differential if you have someone build it for you.
Old Nov 11, 2013 | 04:49 PM
Luke in SA's Avatar
Luke in SA
Thanks guys.
Mike, I have sent you an email.
Old Nov 11, 2013 | 04:58 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
My 4.11 12 bolt direct from Tom's was over $6000 outer axle to outer axle.
Old Nov 11, 2013 | 10:40 PM
brad69's Avatar
brad69
Cruising
I called vansteel and went through this with them on my 69 im building . told them im getting a big block with about 630 hp.so what do you recommend fore the rear. they did a quick figure on rear wheel hp witch put it at about 500 or so,and said going with the 31 spline axles , iner and outer, $1,700 30 spline spider gears $290,and 75-79year half shafts $400 and of course rebuilding the rear,cluches,411 gears and so on. on my 10 bolt. So im in over 3,000, but half the price of a 12 bolt. I also told them that this is a street car and wouldent be going to the track. Just another possible option,dont know how much hp you have good luck Brad
Old Nov 11, 2013 | 11:26 PM
Bud2's Avatar
Bud2
Bud2
G'day Luke,
I had Gary build my Super 10 bolt back in 2011. I've got 530 trying to rotate my 275 MT tyres. The diff cost me about 3500 A$ to get to Melb. All reports point out that Mike and Gary are both top notch with their diffs. The rest of the parts are listed through Tom's site or Vansteel. In my opinion, I'd rush! Don't think the Aussie dollar will stay as strong as it is at the moment. I've ordered all new interior and a Keisler 5 speed for next years projects.
Hey, on another matter, we're having a big Corvette only show down here in Warrnambool, Vic. Good prizes! Jan 26. Bring a CONVOY down to it if you're free.
Bud.
Old Nov 12, 2013 | 04:56 PM
Luke in SA's Avatar
Luke in SA
Thanks for the replys.
Food for thought.
Bud, Might see if I can get down to Warrnambool. Sounds good.
Old Nov 16, 2013 | 09:35 AM
lurch59's Avatar
lurch59
Cheers.
I just did a similar installation in my 69. You need to decide if you want a 1480 vs 1350 axle kit for starters. The 1480 involves cutting the battery box and other fiberglass areas to make room for the u joints.
The only gear ratios for a Tom's 12 bolt are 3.73, 4.11 and 4.56 because a bigger ring gear won't fit in the case.
6800 for the 1480 kit, 6300 for a 1350 kit, doesn't include trailing arm rebuild.
I've got a brand new Toms 12 bolt 3.73 still in the crate in my garage if you're interested. It's for a 1350 axle kit, and I have the receipt.
Old Dec 29, 2013 | 10:19 AM
Argiris70's Avatar
Argiris70
Do you have a complete differential or just the gears ?/
Old Dec 29, 2013 | 12:39 PM
lurch59's Avatar
lurch59
I've got the complete differential. It's got the 30 spline heavy duty stub axles, and of course this needs the heavy duty spider gears. The 12 bolt ring and pinion will only work on the 12 bolt posi units, which are stronger and thicker. The 10 bolts tend to crack and wear the cross shaft hole bigger, depending on application of course. It's set up for the 1350 u joint kit, I also have some new Van Steel trailing arms and Dick Gulstrand trailing arms with 31 spline spindles.
Old Dec 29, 2013 | 01:47 PM
v2racing's Avatar
v2racing
I built a Super 10 for my 75. I used the 30 spline stub axles and spider gears, Richmond 4.11 gears, larger cross shaft, polished the posi case, and put the steel bearing cap on with larger bolts. I bought 3.5" Denny's Nitrous Ready half shafts and used Tom's spindles in VB&P offset trailing arms.
I set the posi up per Tom and Gary's spring-less method, but I'm still a little wierded out by that. I've built plenty of differentials, but never without springs.
I've got my motor, trans, drive shaft, and full rear drive and suspension ready to go, but none of it in the car yet. I'm anxious to try it!
Old Dec 29, 2013 | 03:10 PM
Argiris70's Avatar
Argiris70
PM sent.
Thank you.
Old Jan 21, 2019 | 10:11 PM
gkull's Avatar
gkull
My stock original 79 yokes wore away in less than 50K miles past the C clips destroying the rear end. I bought back in the 80's a built up Tom's rear end with 17 spline hardend yokes from Mid America. I failed some posi units with broken cases and finally bought the Tom's stage 7 posi units. They were the polished units with a bigger pin. I put together another rear end with my 4.11 gears and extra steels to make the rear end super posi because it is so tight. It still has springs. Gary builds really nice stuff
Old Jan 22, 2019 | 08:57 AM
v2racing's Avatar
v2racing
Holy late reply George! Five years?
Well I've got some miles on this setup and it works great. F1 Supercar tires rarely hook solid, so not the same as track tested though. I was a little apprehensive about running no posi springs, but I have to say you step on it and both tires spin and it goes straight every time with none of the clunking around corners you can get with the springs. I'm happy.
Mike
To Toms 12 Bolt Diff Conversion
