rebuilt engine question.
Old Nov 12, 2013 | 06:51 AM
gingerbreadman1977's Avatar
gingerbreadman1977
Default rebuilt engine question.
I finished a full rebuild about 8 weeks ago on an engine but the rest of the car wont be ready for about 4 months. I can go in 2 directions. 1 start the engine early before the rest of the car is ready or just let the engine sit awaiting the rest of the build. I know crate engines sit for ages before being sold sometimes but i dont know what is best for it. I generally go find some big hills when running in an engine but i wont be able to do that obviously till the car is fully running.
Old Nov 12, 2013 | 06:52 AM
Gordonm's Avatar
Gordonm
Let it sit. If it is well lubed up and kept dry you should be fine.
Old Nov 12, 2013 | 08:34 AM
joewill's Avatar
joewill
is it in the car and all hooked up? then fire it up just for grins.. if on a stand then no.. too much effort.. no exhaust, timing, safe fuel source, gassing you out of the garage, police giving you tickets for noise...
Old Nov 12, 2013 | 10:05 AM
oldschoolvette's Avatar
oldschoolvette
Old Nov 12, 2013 | 11:58 AM
billla's Avatar
billla
St. Jude Donor '14
It's not really a problem - make sure you bag it airtight!
Old Nov 12, 2013 | 01:59 PM
TWINRAY's Avatar
TWINRAY
and prelube it before startup
Old Nov 12, 2013 | 02:03 PM
TimAT's Avatar
TimAT
Just bag it and pre-lube just before you get ready to start it for the first time. Cover the openings so they don't collect birds, bugs, and trash.
Old Nov 12, 2013 | 06:16 PM
Bud2's Avatar
Bud2
Bud2
I'd go the other way. I'd put it on a test stand and run it in for the 20 min. Maybe put it on a dyno as well. THEN store it. I'd want to know if it's really ready to go before I go through the work of putting it in the car only to have to yank it out for some little item that was overlooked before. Mistakes do happen. Well they do to me - maybe you're immune. Even then, I'd put the drill on it to pre-lube it again before starting.
Either way, good luck.
Bud.
Old Nov 13, 2013 | 09:14 AM
spikebot 81's Avatar
spikebot 81
I bought a 350ci engine from a guy that had it stored in his heated garage for 5yrs. It was built by a machine shop in seattle, oiled up and baged. All I did was pre lube the engine via the oil pump shaft and made sure there was oil preasure and oil to the rocker arms. No issues on start up and break in. That was 2 yrs ago and engine runs great.
Old Nov 14, 2013 | 02:02 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Rod and main journals/brgs should have grease on them and will be ok. Cyls should have some protection. I use trans fluid - burns off easily on startup. Squirt small amount in each cyl then turn eng over by hand a few or several times and u will be good for years.
cardo
Old Nov 14, 2013 | 08:10 AM
Indiancreek's Avatar
Indiancreek
Or bag up all the holes. If the carb is on put the filter on and tape the holes there also. Mice find all kinds of odd places to live.
Old Nov 14, 2013 | 08:27 AM
7t9l82's Avatar
7t9l82
lube it up , bag it and put an open can of freeze dried coffee in it as a desiccant . that will absorb moisture and keep the rust down. when you take your engine out it will smell good, just don't use the coffee afterwards
To rebuilt engine question.
