R134a Conversion
Old Jul 7, 2002 | 06:20 PM
Ben Taylor's Avatar
Ben Taylor
Default R134a Conversion
My AC was completely empty, so I put in one of those R134a kits with the oil. Last summer my AC worked great and when I would chack the hoses after I turn the car off the low pressure one was always cold to the touch. But now I get air that isn't nearly as cold as before, and the low pressure pipe is slightly warm, (everything else in the engine compartment is really hot) The compressor appears to be working correctly and I still have plenty of pressure left in the system, is there anything I need to adjust?
Old Jul 7, 2002 | 06:36 PM
Larry B.'s Avatar
Larry B.
Default Re: R134a Conversion (Ben Taylor)
R134a is very sensitive to the correct amount. R134a also leaks easier than R12. You need gauges to know if the charge is correct.
Old Jul 7, 2002 | 06:56 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: R134a Conversion (silvervetteman)
Ben my engine builder released my freon and is not EPA certified nor will he return the A/C to the working condition that it was in when I drove the car in. What are the steps to charge the freon and where did you get it? As far as I know in California it is not available to the public.
Old Jul 7, 2002 | 07:39 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
I found the web-site below while looking for a condenser for my '80. It is stated that to properly convert to 134-A approimatly 25% more condenser capacity is required. This company claims to accomplish this with their hi capacity condensor. The 30.5" X 15" for $81.00 looks close to the Corvette size to me and is really pretty reasonable in price. I'm going to order one for my car. JIM
Arizona Mobile Air Inc.
Automotive Air Conditioning Specialists.
Universal Parallel Flow Condensers
R134a compatible
1/3 more efficient than standard condensers, a must when converting to R134a.
Can also be used with R-12 and alternative refrigerants.
High performance auto air conditioning systems. Quality a/c auto / truck systems and parts.
R134a or R12 compatible.
AMA warranties the automotive air conditioning components listed herein to be free from defects in material and workmanship under normal use and service for a period of 12 months from date of purchase. No agreement or promise is made to reimburse for labor or refrigerant losses involved in the replacement of these parts.
There are no representations, warranties, or conditions express or implied, statutory or otherwise, except those herein contained. AMA assumes no liability for damages, losses or injuries, that may arise from use of or inability to use these products.
Part Number Condenser Description Price
12-0437C 14 x 22.5 (Condenser straps included) $ 66.15 plus freight
12-0438C 14 x 26.5 (Condenser straps included) $ 72.90 plus freight
12-0439C 12 x 22.5 (Condenser straps included) $ 66.15 plus freight
12-0440C 12 x 26.5 (Condenser straps included) $ 67.05 plus freight
12-0544C 14 x 21 (Condenser straps included) $ 63.90 plus freight
12-0568A 15.5 x 30.5 (Condenser straps included) $ 81.00 plus freight
12-0632A 10.5 x 27.5 (Condenser straps included) $ 67.05 plus freight
2046AE 19.5 x 14.5 (Condenser straps included) $ 62.72 plus freight
:cool:
Old Jul 7, 2002 | 08:07 PM
Larry B.'s Avatar
Larry B.
Default Re: R134a Conversion (Cali,77,L-82)
Anyone can buy R134a but not R12. You must have a vacuum pump and gauges at the least to correctly charge your system. There is a lot of good info on line about doing A/C work. Do yourself a favor and research the topic so you won't get ripped off and pay too much for service. Even if you don't do the work it is to your benefit to know about it.
To R134a Conversion
