Carb?
Old Jul 7, 2002 | 10:47 PM
Indy Year 25's Avatar
Indy Year 25
Default Carb?
I have a '78 L82 automatic. At WOT it runs through first and second fine. Just after shifting to third (about 70 mph) it bogs, or shuts down.
As far as I know everything is stock except I have a 14 X 2" K&N type open element air cleaner. The curb side valve cover has a breather and smog has been removed.
After the car sets a day or two I have to pump and pump and pump..........to start it. Seems to require even more pumping that others have posted about.
Time to rebuild carb? Fuel pump? Fuel filter?
Old Jul 7, 2002 | 11:01 PM
oger's Avatar
oger
Default Re: Carb? (Indy Year 25)
Sounds like a fuel problem. Pump or filter. The carb should be alright if it gets that far.
Old Jul 8, 2002 | 02:39 AM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Try one of Lars's loaner carbs and see if that cleans things up for you.
Old Jul 8, 2002 | 08:59 AM
QuickVet's Avatar
QuickVet
Default Re: Carb? (The_Dude)
what carb is it? quad or holley?
Old Jul 8, 2002 | 10:47 AM
Tex71BB's Avatar
Tex71BB
I just read in Chevy Hi-Performance that because a Quadrajet has such a small fuel bowl, sometimes a weak fuel pump can't keep up with the demand - since you're OK thru 1st and 2nd, this could make some sense.
I had the same thing. Took the carb off this weekend and put JB Weld on the infamous bowl plugs - now it fires right up after sitting all night.
Old Jul 8, 2002 | 09:24 PM
Indy Year 25
Default Re: Carb? (QuickVet)
It's a Q'jet
Old Jul 8, 2002 | 09:27 PM
Indy Year 25
Default Re: Carb? (Tex71BB)
Exactly where are the bowl plugs? Is a lot of disassembly required?
Old Jul 8, 2002 | 09:30 PM
Rick C.'s Avatar
Rick C.
Default Re: Carb? (oger)
change that pump and filter! then see how it runs you won't be hurting yourself any. as I would never do a new carb without new pump and filter anyway. and if that fixes it you are done. :yesnod:
Old Jul 8, 2002 | 10:57 PM
Indy Year 25
Default Re: Carb? (Rick C.)
That's what I'm thinking. I'll probably try the filter first to see if that fixes it.
That would be a cheap fix.
Thanks all for your comments!!
Old Jul 9, 2002 | 09:05 AM
Tex71BB's Avatar
Tex71BB
The plugs are reached fairly easily. You have to remove the carb and remove the throttle plate on the bottom of the carb (the bare aluminum piece that houses the throttle butterflies). You can then see the plugs. Here's the little buggers you're looking for:
Just put a dab of JB Weld on each one and you're good to go!! Good luck!
Old Jul 9, 2002 | 12:52 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Does it bog right as it shifts and then clears out and runs ?
Does it help if you lift the throttle right before the shift ?
If so, a weak secondary air valve spring is most likely the problem. It is letting the secondary air valve stay open when the shift occurs. As the RPM's drop, the engines need for fuel and air drop. If the valve hangs open you end up sending too much fuel and air for the motor, until the motor catches up and "clears out".
Old Jul 9, 2002 | 07:37 PM
Indy Year 25
Default Re: Carb? (BSeery)
Tex71BB, thanks! The location and pic is very helpful!!!!
BSeery, it bogs down after shifting. When I let off it runs fine. I haven't pushed it after it bogs. I am usually doing a quick run up, and doing 70 in a 45 zone near my house. :eek: (It's 2 lane asphault county road that is as wide as a 4 lane hiway. ) 45 :confused:
Old Jul 21, 2002 | 10:37 PM
Indy Year 25
Well, my problem got worse. It started bogging down about 45-50.
Yesterday morning I changed the fuel filter. Took it out for a drive, and was afraid I wasn't going to get it back home. Cutting out real bad. Even died at a stop sign, and I had a hard time getting it started again.
So, I got a new fuel pump and installed it. This morning I took it for a drive. Seemed to be running better than ever. Then it started bogging down again. It seems to get worse after driving 5+ miles.
I thought maybe I had some bad gas (does that still happen) so I added half a tank of 92 octane to the 87. No help.
If I accelerate real slow I can get it up to about 60 before it cuts out. I have to leave it coast for quite a while before it will run again.
This started suddenly. I had not done anything mechanical to the car that it could be related to. I even tried switching back to my original air cleaner :nonod: . Something wore out, broke, went out of adjustment????
By the way, when I was under the car yesterday I noted that I have true dual exhaust. I was thinking it could be the cat but, there isn't one.
Any idea, suggestions? (I hate diagnostics) :confused:
Thanks for your help. I really appreciate you guys, and gals.
Old Jul 21, 2002 | 11:00 PM
VolVette's Avatar
VolVette
I like to try the cheap fixes first. I recommend putting some fuel injection or carb cleaner in your gas tank and cruising for about 15 minutes allowing the additive to thoroughly go through the jets. Maybe there was some grime in your filter that made it to the jets and are bogging them down.
Also, I am not familiar with QJets but do they have meteriring rods? I dropped a metering rod down inside the float bowls and this really put a damper on any driving.
Old Jul 22, 2002 | 03:06 AM
R. Bruno's Avatar
R. Bruno
Default Re: Carb? (VolVette)
Since it gets worse after 5 miles that may be when the engine has heated up sufficiently for the choke to pop off which make me think that for some reason the carb is starved for fuel. Since you have eliminated the fuel pump and filter and it happened suddenly, consider rebuilding the carb.
Old Jul 22, 2002 | 09:46 AM
Indy Year 25
VolVette, I think I'll try the carb cleaner. Can't hurt.
I don't know anything about Q-jets either.
R. Bruno, I guess if the carb cleaner has no effect the rebiuld is next.
When I got the fuel pump at Autozone they said if the filter and screen were not changed at the same time, the warantee on the pump was void. Is there a "screen" on my 78? If so, where is it?
Old Jul 22, 2002 | 09:51 AM
page62's Avatar
page62
Also make sure your fuel lines aren't pinched anywhere. Especially the rubber hoses from the pump going back to the top of the frame.
But methinks you're going to need to rebuild/replace the carb. It's probably a good thing to do anyway! :yesnod:
To Carb?
