Prudent Choice
Old Nov 15, 2013 | 06:51 PM
oldschoolvette's Avatar
oldschoolvette
Default Prudent Choice
I have to change the rear-end pinion seal. Do you think it would be prudent to change the U-Joints in the drive shaft while I got it out?
They are showing a little wear and tear.
If so what brand of U-Joint? Spicer... Brute Force ... or like a regular Eckler's House Brand?
Old Nov 15, 2013 | 07:02 PM
kanvasman's Avatar
kanvasman
without a doubt. Sometimes we all get carried away with the YOU MIGHT AS WELL thing, but snce it's apart and they are relatively cheap, why not. Think about how expensive it would be for one of them to let go on the side of a road one night. For the cost of a tow you can replace all of the ujoints.
Old Nov 15, 2013 | 07:12 PM
Peterbuilt's Avatar
Peterbuilt
You can pull the caps off the U joints and inspect them and then decide what to do.
Old Nov 15, 2013 | 07:35 PM
v2racing's Avatar
v2racing
I use the solid Spicer u-joints. If there is any wear at all in the joints, replace them while it's out.
Make sure you mark where the nut is tightened to on the pinion and only tighten back to this point. Tightening it beyond where it is setup now can cause pinion bearing failure from loss of clearance.
Old Nov 15, 2013 | 07:47 PM
Peterbuilt's Avatar
Peterbuilt
And mark the front drive shaft yoke so it goes on in the same position it came off.
Old Nov 15, 2013 | 07:57 PM
oldschoolvette
awesome input. My gut tells me the U-Joints is a no brainer
what brand?? do I need to spend the extra Jack or is anything made in USA ok for a 350 hp mill?
Old Nov 15, 2013 | 08:11 PM
TimAT's Avatar
TimAT
The solid Spicer U=joints are the strong ones, but for your application, other than the need to grease them, just about any of the USA made joints will work. (The Spicer joints for my half shafts are about $17 each.)
Old Nov 15, 2013 | 08:14 PM
oldschoolvette
thanks
To Prudent Choice
