fuel pressure woes
I dont know whether it is because of the hot weather in addition to the non-coated headers, or if its something wrong with the pump or regulator setup. I have one side of regulator outlet with the gauge and fuel line to the carb, with the other going to the return line with a 3/8 NPT x 1/8 NPT reducer to keep the pressure up towards the carb, but have a 3/8 hose on that 1/8 NPT cause it was a stainless braided line I had laying around, but didnt think it was that cause it still should be hold the pressure back from the reducer?? correct?
anyone have any ideas why this is happening?? I need to get this fixed so I can spray already~! :jester :lol:
[Modified by 74VETTE, 11:28 PM 7/7/2002]
or is it safe to spray the nos if the fuel solenoid has around 10 psi since the supply is before the regulator, but the carb only has 4-5 psi since its after the regulator and im getting that 4-5psi reading on the gauge?
id rather figure a way to get the pressure up a bit though.
here is a bootleg schematic of my setup
thanks again
Chris
[Modified by 74VETTE, 11:27 PM 7/7/2002]
