Quick Brake Question
Old Nov 16, 2013 | 10:03 AM
micks69's Avatar
micks69
Default Quick Brake Question
On my 1978 I'm replacing the rear brakes. There is a spacer shaped like a flat disc. Does it go under the disc on the hub or over the disc and under the wheel or is it just some crap someone put on at some time in the past. I removed it from under the disc.
TIA
Old Nov 16, 2013 | 11:15 AM
ddawson's Avatar
ddawson
Sound like a shim to keep the rotor straight.
http://forums.corvetteforum.com/c3-t...tor-shims.html
Old Nov 16, 2013 | 11:22 AM
micks69's Avatar
micks69
I think its "custom" as has been many other items on the car.
With the new rotor on without it the rotor rides right in the middle of the caliper with it its off to one side. Some people shouldn't touch a Corvette. I believe it might be some sort of wheel spacer. But that should go on the outside of the rotor not on the hub. No wonder his new brake job sucked air and couldn't be bled.
Old Nov 16, 2013 | 11:31 AM
gg521's Avatar
gg521
It could be a wheel spacer. How thick is the disc? If it's about 1/4" or so that is what it is. Used to get less back spacing for the tires and wheel. This goes over the hub and behind the wheel. Large tires come very close to the rear spring.
Old Nov 16, 2013 | 11:34 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by micks69
With the new rotor on ........
Are you set up to measure and correct the surface runout?
Old Nov 16, 2013 | 11:40 AM
gg521's Avatar
gg521
Oops, I missed the part about being under the disc. How can the rotor be in the middle of the caliper and off to one side at ther same time?
Old Nov 17, 2013 | 09:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I think its "custom" as has been many other items on the car...
I think it's a shim. You say you replaced the rotors. Were they already drilled out? If so, the shim was added by a PO.
...No wonder his new brake job sucked air and couldn't be bled...
With new rotors you have to check run out.
To Quick Brake Question
