I just recently purchase a 76 and have been driving for 2 months. it has progressively been getting worse with engine cut out when I hit the gas from a stop - runs fairly well once out of first gear. It backfires from time to time as well.
Couple items:
there are no catalytic converters
carburetor is due for a rebuild
plug wires were replaced in August
new air filter in August
last cap and rotor replacement and timing set from records was 2005
I hopped in the car today - the engine turns over but now wont start. Any help on where to start?
anybody in Kansas City area who may be able to help? My regular mechanic wanted $600 for a tune-up so I told him to fly a kite since I know that is highway robbery!
Probably best to post in your regional forum for someone to come and help out.
Not sure my answer is helpful - timing, then carb. It sounds like possibly the distributor is slightly loose and has been slowly taking out timing to the point now where it's not going to start.
All that's required for a tune up is a cheap dwell meter (if needed for points), a timing light and a little time.
There are a few things that you can look at for yourself with a small amount of mechanical ability. Make certain that you have fuel flow to the carb, check to see if you have spark. You can also remove a spark plug and make sure that you have compression. That one requires some knowledge of compression characteristics though. Since it has been getting worse as time passes and difficult to start now, I would look closely at the fuel supply, such as a plugged fuel filter or failing accelerator pump. Sorry that I can not be of more help from this distance but, that gives you some place to start. If you are not rich, you should learn how to work on these cars or ownership will not be the best experience. They are relatively easy cars to learn on and fun to drive. Best of luck!
thanks gents! I'm fairly mechanically savvy, so I don't have any problems tearing into it! I just replaced the brake booster and master cylinder fairly easily given all the info available on this site!
I will pick up a timing light and a new cap and rotor are on the way. I just didn't know if there may be other issues based on everyone's experience. At least I know I'm going the right direction. I can smell fuel, so don't think that's the issue but will replace the filter and go from there.
I'll keep ya posted if I run into additional snags. May just need a quick second pair of hands with more experience than I currently have. I really appreciate the quick replies!
if you have no spark at the plugs,test for power to the distributor .is the choke open or closed ? do you have oil pressure ?take the distributor cap off and make sure the rotor is turning .hope your timing chain didn't jump a tooth or 2 .
managed to at least get it in the garage. it tries to start but is obviously missing - has an almost bogged out type attempt at starting. something has definitely changed quickly as it drove almost perfectly yesterday.
pulled the distributor cap and it looks a little worn.
[IMG]
I can spin the rotor with effort but feels solid. nothing else moves so assume that's good?
I have never adjusted the timing but certainly up for it if that's the issue. A timing chain slip sounds like an entirely different story and one maybe beyond my ability unless I want it in the garage for a month....how would I know if it was the chain?
and....only way it comes even close to trying to start is if I manually open the choke and get gas into the carb. manually moving the linkage and I can see gas flow freely - so it may be a host of issues simultaneously.....
That cap has a pile of carbon on the terminals, time for it to go. Assume when you say you can "spin" the rotor that you mean you can rotate it a short distance and then it will spring back if you let go?
If so, I doubt it is a timing issue.
Have you checked for spark yet? That is always step one for me. Pull a wire and use a spare plug to test...get someone to bump the ignition over for you while you look for a spark (unless you have a light). That will answer the question about spark pretty quickly in most cases.
If there's no spark, a common culprit on your car is the HEI module.
If you have spark, then look at fuel delivery problems. Change the filter as a matter of course if you haven't already, but maybe you're looking at a gummed up needle and seat in the carb. Happens all the time, and can get progressively worse. Commonly this causes a flooding condition as well, which you don't seem to have.
Cleaned all the terminals and the rotor. Reinstalled and she fire right up! Still drives a little sluggish but.....maybe related to the distributor? I rotated a little each way, BUT it does not 'spring back'. There is about 1/2" of rotation available forward or backward, but it will stay when I let go.
I have a new rotor and cap coming along with new spark plugs and wires. I know this will help, but maybe someone can point me in the right direction on what to do with the distributor not springing back - I assume I need it overhauled or replaced to avoid further issues down the road?
Thanks for everyone's feedback!!! at least I have a running car at the moment - and there is no hesitation from a stop.
In terms of the "distributor not springing back", what was being referred to is the advance plate inside the distributor, not the whole distributor.
Yes.
Better check your timing at this point...especially if you are moving the whole distributor, at all.
Sounds like your advance springs and weights might be in rough shape. Based on the amount of carbon that the cap showed, I'd pull off the rotor and have a look under there to see what it looks like.
advance springs and weights are rusted.....didn't dig into it beyond pulling the rotor off - kind of an oh crap moment I suppose. Is pulling the whole distributor easy enough without special tools and what are the tricks I need to know so I don't jack up the timing when i pull it/replace it?
I dug through all the documentation I have on the car from the previous owner and I don't see the distributor has ever been replaced/repaired. Last cap and rotor swap was in '01. New plugs were put in a year ago and new wires were just put on. Not sure why everything done at separate times but is what it is. I'm doing all this weekend, but it sounds like I may want to get a distributor on order as well and remove that problem too unless there is a simpler solution?
I would suggest not pulling the trigger on a new distributor until you have to. The upper end getting rusty and sticking is a pretty easy fix. Pulling the distributor and checking all the bushings and cleaning it all up is easy, as is getting it re-installed and setting up the timing and curve.
As I said, I'll be home the 22nd for a couple of weeks and will be happy to take a look and assist you with fixing whatever it needs.
If your distributor is past an easy fix, I have located a source in KC for new. (probably made in China, but they do work- I bought one for another project)
Once I get the "honey-do" list over with- I'm pretty much loose. Give me a day's notice and we can get it running like it should.
With Tim on the distributor...try to rebuild it first if that ends up being necessary rather than dumping it for a new one. I've found that old and restored is frequently better then new when it comes to cars like ours. Good luck.
