Noise in rear
Old Nov 18, 2013 | 09:37 AM
blue by you's Avatar
blue by you
Default Noise in rear
Need alittle help. Went for a drive and noticed a noise in the rear drivers side. Jack up the rear no play in the tire 3 to 9 or 12 to 6 pulled the tire and caliper off, and turned the axle and can hear a noise think it is the parking brake.
I noticed the rivits are still in the rotor so what size drill bit do i use and how easy are they to drill out, any thing i need to know about.
Old Nov 18, 2013 | 11:15 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The rivet is about 5/16" the head is 5/8" but you don't want to damage the rotor. I'd use a 3/8" or so if you can keep it on center. You only need to cut the head loose. what kind of noise is the car making? A tinning sound?
Willcox
Old Nov 18, 2013 | 11:21 AM
blue by you
It is a tinning noise that goes with the wheel turning so it is when it goes around you hear it every revolution
Old Nov 18, 2013 | 01:55 PM
0Willcox Corvette
Former Vendor
It may be a simple as one of the springs that hold the top/bottom of the shoes together. Make sure you mark your rotor before you take it off.
Old Nov 18, 2013 | 02:00 PM
blue by you
mark it for what side it comes off or another reason
Old Nov 18, 2013 | 07:42 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
It is best to put it back on with the original factory orientation. The run-out was set with the rotor mounted on the hub so it is best to put it back the way you found it. Most of us ended up with a car that had already had the brakes "repaired" so the rotor may or may not be aligned correctly.
Old Nov 19, 2013 | 07:59 AM
blue by you
i just noticed the noise it seems to be every revolution not constant
Old Nov 19, 2013 | 11:43 PM
ChristianAnarchist's Avatar
ChristianAnarchist
Had a noise that occurred when turning and sounded like a clunk clunk in the rear. The man I have do a lot of my maintenance told me that the differential needs to have a special additive in it for the limited-slip to work correctly and smoothly. He put it in (don't know the name) and the noise has gone away. It appears the clutch was just "grabbing" when turning even a little radius...
Old Nov 20, 2013 | 09:26 AM
blue by you
it's not a clunking noise had that when i bought it changed the fluid and all was good this is a scraping noise that i can hear when i turn the axle by hand.
Old Nov 25, 2013 | 08:18 AM
blue by you
ok had time this weekend to work on the car. Drilled the rivets out no problems there, when i took off the rotor 2 springs fell out and were beyond repair, guess i need to order some parts. put it back together for now and have no noise at least.
To Noise in rear
