Front Crossmember Broke
Old Nov 20, 2013 | 12:32 PM
jlaw68's Avatar
jlaw68
Default Front Crossmember Broke
Had a little incident Monday morning in my 78. Had a driver pull out in front of me, had to lock up the brakes and bumped a curb. When I did, the front crossmember gave where the lower control arm bolts to it. I have done some research, but what I can't find is, is the front crossmember welded to the front of the frame or can it be unbolted and taken out to be welded up stronger.
Here is what it looks like. Any help is much appreciated.
Old Nov 20, 2013 | 12:34 PM
MelWff's Avatar
MelWff
I do not believe it comes out but a competent welder should be able to fix that in place after removing the arm.
Old Nov 20, 2013 | 12:49 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Pretty common break point. You can see the rust where it was cracked for some time.
It can be welded up nicely and do fine.
JIM
Old Nov 20, 2013 | 03:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by jlaw68
...is the front crossmember welded to the front of the frame...
Yes. Welded. It does not bolt up.
Old Nov 20, 2013 | 03:53 PM
hugie82's Avatar
hugie82
I guess it's a good time to order the front end bushing kit while you have everything blown apart
You have a lot of good metal and it looks like you can tap it right back into place. My best advise is clean the cracked areas inside and out. That's going to be the time consuming work. Welding it up looks like a 10-15 minute job
Old Nov 20, 2013 | 03:57 PM
speedreed8's Avatar
speedreed8
I had a similar curb accident to mine several years ago, the lower bracket can be had at Zip- corvette. it took me two months to fix mine. a welder some metal and some beating with a hammer and some time , it can be repaired. good luck.
Old Nov 22, 2013 | 09:24 PM
jlaw68's Avatar
jlaw68
Thanks for the responses. I'm starting to feel better about this being able to be fixed. Had that sick feeling in my stomach most of the week about it.
Old Nov 22, 2013 | 09:33 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Yep. The same thing happened to me. Broke loose from the back side of the crossmember. A good welder can fix it with no problem.
Old Nov 22, 2013 | 09:37 PM
jlaw68's Avatar
jlaw68
Anyone care to throw out what they paid to have it done. I'm a fair mechanic, but I'm by no means a welder.
Old Nov 22, 2013 | 09:41 PM
RickyBerg's Avatar
RickyBerg
Jeesus, that doesn't look nice..
When you have your crossmember repaired there are some easy made reinforcements you can add to strengthen it up a bit.
The major one is to complete all the welding that GM only did half of.
Next is to add some profiles that was added on the racecars.
This will add significant strength to your front end.
Old Nov 22, 2013 | 11:41 PM
Brcmpbl's Avatar
Brcmpbl
Pretty cool.
Old Nov 23, 2013 | 01:38 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Oowch, thats bad. U need to close that up and straighten the member before welding. Not to many frame shops these days as most cars are unibody - but u need to look for one. A mechanic found and welded a big crack mine before disaster hit. Wish someone made a good tubular replacement but that would be a cut and weld job also. Ricky B. has a nice fix from what i can see.
Good luck,
cardo0
Old Nov 23, 2013 | 10:44 AM
RickyBerg's Avatar
RickyBerg
Forgotten to say that the upper and lower sections of the front crossmember are only point welded (spot welded?) together (where yours has split).
I welded mine 100% by welding the visual gap where the two sections bind together.
I think i may be wise to look for a replacement bottom section so one can start the repair with undamaged steel.
Old Nov 23, 2013 | 03:56 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Yes have it repaired by a welder,
I worked mine over when I had the engine out,
Many more to add than just in the pics, motor mounts, front frame horns
Mine were cracked all around the lower A-arm mounts and where the cross-member attaches to the frame.
Neal
Old Nov 23, 2013 | 07:55 PM
RickyBerg's Avatar
RickyBerg
Here you can see the full weld securing the earlier only spotwelded sections of the crossmember.
If you are interested there are some more pictures in my garage.
http://forums.corvetteforum.com/memb...-72-18802.html
Old Nov 24, 2013 | 08:37 AM
lvmyvt76's Avatar
lvmyvt76
I replaced mine, got it from california, I think J&D corvette salvage yard. Try Doc's corvettes in Tulsa for parts.
Good luck!
Old Nov 24, 2013 | 01:52 PM
stevelischynsky's Avatar
stevelischynsky
If your worried about originality, I would get the welder to add a brace on the inside first. Then bend the belly pan back and weld around. The belly pan is just some thin sheet metal. You'll need to get a wheel alignment done as well since you'll never get these pieces back to the original place.
If your not worried about originality, add the brace as shown above by RickyBerg. I think the braces by Chevyman is interesting but a little overkill unless you are doing some serious torturous driving.
Steve L.
73 coupe since new
To Front Crossmember Broke
