One head light raises much slower
Old Nov 22, 2013 | 03:15 PM
81 vette vent's Avatar
81 vette vent
Default One head light raises much slower
I have an 81 and one of the headlights raises and lowers a lot slower than the other. I would say 1~2 minutes slower than the other. Any ideas or quick fixes like oiling the actuator. The air lines look pretty good and the connections look good as well. I know there is a directional vavle for each light assembly. could this be sticking or not moving fully?
Old Nov 22, 2013 | 03:54 PM
Dave J's Avatar
Dave J
The headlight system is really easy to diagnose and repair if you understand how it works. Your problem is either the seals on the actuator and/or the relay for that headlight. The actuator front seal is easily replaced after removal from the car. Check it with a vacuum gauge for leaks. The relay is also easily diagnosed with a vacuum gauge.
See the link below
http://forums.corvetteforum.com/c3-t...tem-works.html
Old Nov 22, 2013 | 06:01 PM
Street Rat's Avatar
Street Rat
A relay fixed my '81's "lazy eye".
AGVI's Avatar
AGVI
Canadian Events Coordinator
Go electric/thread
To One head light raises much slower
