Heater hose alterations
Old Nov 23, 2013 | 11:01 PM
newvetman's Avatar
newvetman
Default Heater hose alterations
Ok Forum family I need some help. I need to know what these do and if I need them.
I am now going threw my engine bay and replacing anything that needs it. Today I decided to replace the heater hoses and came across this hot water shut off valve and separate heater control valve. The problem I'm having is that I can't find anything that shows these being used on a 1977.
Can anyone shed some light on these being used on a 1977 with A/C.
[IMG][/IMG]
Old Nov 23, 2013 | 11:30 PM
DaBo's Avatar
DaBo
The one on the left of your pic is 100% aftermarket / non stock. I would guess that the one on the right may have been stock but failed so the other was installed. Although it really doesn't look like a factory installation. Those with an original engine bay will chime in I'm sure.
Given the amount of heat radiated into the cockpit of our cars, the manual valve is a very common addition to stop the flow of coolant into the heater core. Thus eliminating a source of heat during the summer months.
Old Nov 24, 2013 | 09:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Factory air cars for most model years had a hot water shut off valve in one of the heater hoses. Part of your old original is still there (to the right; still has the factory Witteck clamp on the hose).
You will need a replacement. The AIM shows where it mounts. A small vacuum hose from the HVAC controls runs to it.
Old Nov 24, 2013 | 09:58 AM
REELAV8R's Avatar
REELAV8R
The valve on the left was added by someone. The one on the right is stock and looks like the one in my 77.
Problem with it is that it only shuts off water supply when A/C is selected to max cold. All other cooling modes the hot water still circulates through the heater core to mix with cold air in the evaporator to create selected level of cool air.
So the passenger will experience more heat than the driver due to the location of the heater core. This is why the shut off valve is often added to shut off the heater core flow to keep the cabin cooler on the passenger side.
Old Nov 24, 2013 | 10:57 AM
newvetman's Avatar
newvetman
Ok fellas that helps me understand why it was there.
My next question is do I need both of them. The
Car came from New Orleans where shuting off the
Heat in the summer would be very desireable but
I now live in the San Francisco Bay Area where
The temperature is more mild and you may need
Heat in the summer
Old Nov 24, 2013 | 12:17 PM
REELAV8R's Avatar
REELAV8R
The best compromise for moderate temps I have found is to have a shut off valve on one of the two heater hoses. This way the heat is still available to be mixed with the cold air but is not as oppressive because the water is not flowing through the heater core so the core is cooler than it would otherwise be.
I have two shut off valves in addition to the factory one. On really hot days I shut both valves to isolate the heater core completely from the engine cooling system.
Old Nov 24, 2013 | 04:06 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by newvetman
...do I need both of them...
No.
Old Nov 24, 2013 | 04:07 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Down south, I installed a vacuum shut-off on the inlet and the outlet hoses to keep heat out of the cabin (that keeps me from having to go under the hood every time the weather changes.)
I never realized that older vehicles used heater air to regulate A/C temperatures....
Thanks for the info.
Old Nov 24, 2013 | 07:54 PM
newvetman's Avatar
newvetman
Ok thanks for the feed back fellas. I think I like the idea of putting a manual shut off valve on both lines. Its easy enough to pop the hood up and open or shut the valves.
Old Nov 24, 2013 | 08:33 PM
doorgunner's Avatar
doorgunner
OOOOOOOOOOOO-K.........but when you're halfway across town with the heater on hot'n'high.......and you're still shivering........
(Just picking.....I used manual valves for years)
Old Nov 24, 2013 | 09:06 PM
newvetman's Avatar
newvetman
doorgunner I was am understanding that the manual valve is just giving you more control over the heat getting into the core during warm weather. Are you saying you prefer the stock vacuum valve and why.
Old Nov 24, 2013 | 09:30 PM
scottyp99's Avatar
scottyp99
It's not like you're going to be turning the valve on and off every time you want heat. You turn it off at the beginning of the summer, and back on at the end of the summer. Unless you live in New England, like me, then you might turn it on and off half-a-dozen times a year. Not a big deal if you're the kind of guy who likes to open the hood once in awhile, anyway. I've never been out to San Francisco, but Mark Twain said "The coldest winter I ever spent was the summer I spent in San Francisco."
Scott
Old Nov 25, 2013 | 08:28 AM
doorgunner's Avatar
doorgunner
It's just a matter of personal choice---I live down south where during the "winter" the temperature might vary 40* every week for 5 months.
In 50 years of winters---that's a couple hundred hood raises! (It took me about 40 open hoods and a couple times of forgetting to open the valves during cold-snaps to decide to go with two stock heater switch-operated valves which activate when the heater is operated/de-activate and keep the hot coolant out of the heater core when the heater is not used)
For those who live in climates with distinct seasons---Manual On/off valves would be a great idea!
Old Nov 25, 2013 | 10:14 AM
REELAV8R's Avatar
REELAV8R
The OP will want the heater near the bay for sure on cool evenings. I spent many a night at the Oakland airport which is located on the bay and it is quite cool at night.
But on the east side and farther inland it can easily get over 100* so he will also want that A/C on max then. He'll also want highway gears to keep up with the rest of the crazy drivers in that area the go 90 MPH+ in the 65 MPH speed limit interstates.
Old Nov 25, 2013 | 10:35 AM
langg's Avatar
langg
I use a vacuum actuated valve like the original but I added a vacuum valve like the one used on the headlight system. I placed the valve beside the headlight one just at the bottom edge of the inst panel. Gives me positive shut off and easy selection.
langg
Old Nov 25, 2013 | 11:00 AM
REELAV8R's Avatar
REELAV8R
langg
You and Doorgunner have a pretty cool set up. I like that kind of ingenuity and engineering.
Old Nov 25, 2013 | 05:32 PM
newvetman's Avatar
newvetman
I could see that
To Heater hose alterations
Old Nov 25, 2013 | 06:11 PM
newvetman's Avatar
newvetman
langg
Do you have a pic of this set up? It would help me to see it.
Old Nov 26, 2013 | 08:16 AM
gcusmano74's Avatar
gcusmano74
langg
Yep. Did the same thing meself, years ago.
Old Nov 26, 2013 | 10:17 AM
newvetman's Avatar
newvetman
Gcusmano
Do you by chance have a pic of your set up.
My car has fixed headlights and thus no actuator
On headlights.
