start up problems
Old Nov 26, 2013 | 11:02 AM
colo69's Avatar
colo69
Default start up problems
I have replaced the timing belt, and got a valve job, and new oil pump.
Now i cant get the 1972, 454 to run, the starter works fine, i put in new wires and plugs. HEI ignition, 8mm wires. The carb. was also rebuilt. HELP
Old Nov 26, 2013 | 12:37 PM
ShefmonC3's Avatar
ShefmonC3
...you say it cranks fine but will not fire up. Are getting fuel, a spark, backfire's or anything? Really hard to help without more info.
Old Nov 26, 2013 | 01:55 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
72s did not have HEI. Do you have power to yours?
Old Nov 26, 2013 | 04:14 PM
scottw's Avatar
scottw
colo69,
Need some more info. Are you getting fuel and spark? I'm guessing your engine cranks fine. If you have backfiring, you may be a tooth or two off on your distributor or you may be 180 degrees off. I've been there before. Verify you are getting fuel and spark, then reset to TDC and make sure your dizzy is lined up straight.
Old Nov 26, 2013 | 07:32 PM
colo69's Avatar
colo69
i am getting a spark, and sometimes it back fires. i have power to HEI. yes we are getting fuel. the guy i got it from said it was a 427, but i looked up the block numbers which indicates a 454 from a 1972 engine. it is in a 1968 vette. it very cold out 27 degree's. i have had a heater on the pan.
Old Nov 27, 2013 | 06:18 AM
scottw's Avatar
scottw
I think you are one tooth off on the distributor. If it runs for a short period and backfires, you are a tooth off. If it just backfires while cranking, you are probably 180 degrees off. I've been in both circumstances and it is an easy fix.
Good luck. Let us know what you find out.
Old Nov 27, 2013 | 08:48 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Distributor timing. Get the dizzy installed correctly and you should be OK.
Old Nov 28, 2013 | 08:58 AM
lvmyvt76's Avatar
lvmyvt76
someone tell him how to get the dizzy installed correctly. Get a friend that know how and have them check your work. You are identifying #1 correctly aren't you, ford is different than chev.
Who rebuilt the carb??? Did you do all the work?/ Anything done with the cam & lifters?? Connecting rods replaced? Tell us more about engine rebuild.
Old Nov 28, 2013 | 09:46 AM
MrJlr's Avatar
MrJlr
Timing "belt" ????
Old Nov 28, 2013 | 09:51 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
And make sure that there is a ground cable with CLEAN connections from the engine block to the chassis (and a 16 gauge ground wire from the distributor housing to the engine block couldn't hurt matters). You can "get away" without having either ground wire....but it's better to have them.
Also......do NOT use the steel-stranded resistor wire (that previously supplied low-amp voltage to the original firewall mounted coil) to supply voltage to the HEI distributor---the distributor needs a Key-on/12volt copper wire run to the distributor to get max output.
Old Nov 28, 2013 | 11:44 AM
scottyp99's Avatar
scottyp99
Originally Posted by MrJlr
Timing "belt" ????
Maybe that has something to do with why it won't run?
Just teasing, colo69, engines from that era don't use timing belts, they use timing chains, that's all.
Did you do the work yourself, or have a shop do it?
The very first thing I would do, if I were in your shoes, is double and triple check that the plug wires are oriented in the correct firing order, 18436572
Scott
To start up problems
