Low idle with A/C on
Old Jul 8, 2002 | 06:58 PM
Ben Taylor's Avatar
Ben Taylor
Default Low idle with A/C on
When I turn my A/C on my idle drops and sometimes the car stalls. Isn't the idle supposed to go up when you turn the A/C on? I think that there's probably just some screw I have to tighten on the carb, but it's hot outside and I can't think straight right now.
It's a 81 automatic.
[Modified by Ben Taylor, 3:58 PM 7/8/2002]
Old Jul 8, 2002 | 07:01 PM
page62's Avatar
page62
Default Re: Low idle with A/C on (Ben Taylor)
There's a solenoid that is supposed to kick up the idle speed when the compressor kicks in. You'll have to check and see if it's working and adjusted okay.
Old Jul 8, 2002 | 08:29 PM
Ben Taylor's Avatar
Ben Taylor
Default Re: Low idle with A/C on (page62)
Thanks, I got it fixed. I don't know if it's just my imagination, but my A/C seemed colder after I got that adjusted.
Old Jul 8, 2002 | 08:39 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
it may be. you kicked up the engine speed which turns the compressor faster, turns the fan on the radiator and condensor faster and turns the alternator faster so it can put more voltage to the blower and it will then go faster.
To Low idle with A/C on
