Help with a street bound big block?
The owner is disappointed in the lack luster performance of his "stock" Vette. He doesn't want headers or valves that he has to adjust. He doesn't want a hood change because of tall manifold. His idea is a cam change, intake, and carb. The car is actually beautiful. Somebody did an excellent paint job on it.
I'm going to talk to him about H-roller and H-flat options and work out a prices.
He had the motor rebuilt 12 years ago and bumped the compression to 10.5 and he said he might have 10,000 miles on it. So he wants to leave the heads on it. Just new cam, springs if needed, intake, and carb.
So you BBC guys please tell me what is the best low rise dual plane and some thoughts on your cams please.
Hydraulic roller is really the way to go on this thing, and Id leave pretty much everything else the way it was. For simplicity, Im tempted to say throw in a ZZ502 hydraulic roller and use the thrust plate and Gen VI timing set up, but I think that may be a little radical for those cubes.
Im sure there is a hydraulic roller better suited to this set up, but if it were me, that would be the only modification I would make at all.
Here's the general details:
9:1 CR
GM Intake (I have it on the shelf I can get the number off it when I get home if you want to know it)
Holley 850
Side Pipes with baffles
Reeds Solid Roller Cam 284 Duration 624 Lift with 1.7 rocker arms
990 heads (totally stock)
I know its a solid roller cam specs but maybe you can get a hydraulic roller cam that will have similar flow or whatever it is you do with a cam to make the swap from solid to hydraulic and keep the power close to the same.
Roger
I'm going to measure clearance and do some figuring on how tall of a dual plane I can get away with. It is actually a 431 ci because of a .030 over bore and his receipts for the rebuild show TRW forged pistons.
It has a full dual exhaust and kind of louder mufflers.
Changing gearing is not in the works or budget. I just did a rough calc on the gearing and it must be 3.36.
But the owner doesn't want to deal with headers.I need to fugure out what the stock cam specs are and proceed to maybe an additional 10 degrees @.050 and if the lobe center of a stock cam is 114 maybe get down to 110. Tonight I'm going to measure the lift
IMO the stock intake, as limited as it is, is better than the Torker II overall. What he'd pick up in the way of top end power would likely be offset by a stumble coming off of idle. For that reason the Edelbrock techs themselves didn't recommend the Torker II when I was considering it. A swap to the L88 hood would open up some great choices but it doesn't sound like that's an option.
If your customer is on a budget and heads with bigger valves are out of the question, a decent cam and a good tune seem to be what you have to work with. I know you like roller cams, and for good reason, so there you go. Do keep in mind that there isn't a lot of valve/piston clearance with the closed chamber heads. I can recommend some specs on a hydraulic flat tappet that had me running low 12's if you're interested, but that was after the stock heads were set up with the larger valves. FYI, the stock cam is very mild.
This spring I picked up a good bit of throttle response by going more aggressive with my ignition curve. However that was in conjunction with putting in a new MSD distributor, so part of the gains could have been due to replacing the worn out stocker.
Good luck. Too bad about those headers though.
It is strictly a street-driver and has a fairly decent 3.36 gear with a four-speed so a HR that peaks at around 5,500rpm would seem to be a very good fit. The money he'd be saving by not replacing the carb and intake would allow you to move him up to the HR and not affect the bottom line.
I don't have problems with header gaskets or bolts backing out. He is trying to go cheap, But i might say that I'm not comfortable with leaving the heads on. Because of valve clearance and we really don't know for sure what the compression ratio really is other than someones word that it is 10.5. I don't want to get a detonation prone cam.
It is kind of boring to drive campared to my 434 ci small block
Has he had a decent dyno tune by a good shop or have you gone over to ensure everything's working right? It would suck to find out that the only issue was a misadjusted throttle linkage...
This thing has a smooth 600 rpm idle and quiet. The tail pipes look small maybe even just 2 inch.
Just thought I'd ask - but it sounds like it's in good tune and everything is working perfectly
If they want to save their money, well dont mess with the engine at all then.
Leaving the heds on sounds imo like a bad idea..
Pull the heads and verify they are in good condition, check the valve guides and do at least a nice valve seat job.
Intake manifold.. The never ending question..
I have the LS6 manifold and a Holley800 4150 carb on my 454 and it fits under the hood.
I have a hyd roller and the max power of 470hp is at 5500rpm.
The engine pulls strong from 2700rpm and i shift at 5500rpm, no use to rev any higher.
A better intake i think would be a tri-jet setup but then the budget propably gets blown..
the actual compression ratio.I would also reccomend posting the head
casting numbers so you'll know if the heads are open or closed chamber.This sounds like a good time to contact Chris Straub.
With that gear hard to go wrong with an Isky 270 mega or something like that.
I dont help with cheap/budget no more you know how it goes. They wont be happy, youre the jerk and they will spend the money twice anyway. Just cant tell em anything.
