Door Ajar Light--Help Needed
Old Nov 27, 2013 | 09:21 PM
bhk2's Avatar
bhk2
Default Door Ajar Light--Help Needed
Currently troubleshooting the not functioning Door Ajar light on my 69, 350/350 4 speed w/o AC.
The blue and pink wire combo is correct, I have power to the bulb socket, and the bulb works--just not here. Do I have a ground issue?
Thanks for the ideas
Door Ajar Bulb Socket
Power to the Bulb Socket
Old Nov 27, 2013 | 10:45 PM
'75's Avatar
'75
The lt blue wire should get grounded by either of the door ajar switches when the door is opened. The door ajar switches are the ones at the rear of the door.
Old Nov 27, 2013 | 11:40 PM
bhk2's Avatar
bhk2
Thanks, I'll check if the blue wire path travels to the door switch--wouldn't have thought to look there.
Old Nov 28, 2013 | 05:32 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
My '68 project car door lite does weird things too....if I tap the driver's door switch a few times in/out----the light comes on....there is a separate ground wire from the door switch to the metal chassis.
Also......the ground wire at the horn relay bracket on the feder well was loose causing the dash warning lites/turn signals to do some goofy stuff.
(Side Note: It's 4:30 a,m. here....but the post says 6:30 a.m.......must be that international clock??????)
To Door Ajar Light--Help Needed
