rpm's decrease when brakes applied
Old Dec 2, 2013 | 03:04 PM
ttoptom1's Avatar
ttoptom1
Default rpm's decrease when brakes applied
Reconfigured vacuum lines today and notice rpm's decrease aprox. 150 when power brakes applied-don't remember this before-I ran dedicated vacuum to booster that PO had spliced into before-68 327/350-Is check valve going bad or normal? Ran booster from full vacuum at back of Holley carb-Thanks
Old Dec 2, 2013 | 03:49 PM
MelWff's Avatar
MelWff
What is your normal idle speed? Automatic or manual transmission? Did you readjust the mixture screws after your reconfiguration? Stepping on the brakes at idle normally does cause an idle speed change but not necessarily down, usually up.
Old Dec 2, 2013 | 09:16 PM
ttoptom1's Avatar
ttoptom1
Did not readjust mixture screws_forgot that could change A/F-will try tomorrow-4 speed-normal was 850-900-still new at trying to optimize carb performance-after reading posts lots I need to learn
To rpm's decrease when brakes applied
