1975 L48 motor upgrades
Old Dec 4, 2013 | 08:53 AM
John485garage's Avatar
John485garage
Default 1975 L48 motor upgrades
Hi everyone,
I'm a new owner of a 1975 corvette. Just wondering if anyone out there has made any modifications to increase performance/HP without spending to much money?? My vette has matching numbers, t400 auto & mileage is 78k.
thanks
Old Dec 4, 2013 | 08:58 AM
mk's78's Avatar
mk's78
Default Save your $$$
Originally Posted by John485garage
Hi everyone,
thanks
Do yourself a big favor and save your $$$....just drive it and enjoy it....
I have a stock 78 L-48.......and it is what it is.......and I enjoy driving it as is!!!!!!
mk's 78
Old Dec 4, 2013 | 09:02 AM
Revi's Avatar
Revi
There's not much sense dumping money into a 1975 L-48. Other than adding headers and a non-cat duel exhaust (illegal in some states) you would be better off with a crate motor.
Old Dec 4, 2013 | 09:51 AM
John485garage
Hi mk's78. thank you for your input. When I got it, someone changed out the original carb. with a holley light truck carb.?? Don't know why they did that, so off came the holley & on went the rochester quadajet 4-barrel like the original. All of the anti-pollution stuff was removed also, and dual exhaust was installed like the 1974 model year. So, yes your right, I'm just going to enjoy it they way it is.
Old Dec 4, 2013 | 09:56 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I agree to a point. A 75 model engine with 78K miles is not going to be a great starting point for a high performance engine, but could be fine for a better performing one.
Headers and better exhaust are a good start. Have the distributor recurved (this helps a bunch) per Lars papers. Search the site for Lars information. Use a 180 degree thermostat with your new ignition setup. Switch out your intake manifold for an Edelbrock Performer and use your current carburetor. Anything else gets you inside the engine seriously.
This would give you a noticeable improvement in seat-of-the-pants performance and possibly better gas mileage.
Old Dec 4, 2013 | 10:04 AM
John485garage
Hi Revi,
thank you for your input. I would like to keep the original motor, but if this motor gives me any problems, or blows up, I would probably look into a crate one. It's an ice cream car and don't plan on racing it, just cruising.
Old Dec 4, 2013 | 10:14 AM
jnealg's Avatar
jnealg
john,
I am in the same boat, 75 l48.
The PO put dual exhaust and stripped the cats. I am not going to sink any money in to it. No headers or anything. I'll throw some lipstick on that pig with a couple of chrome pieces but I am saving for a 383 myself.
its nice to tool around in and look at but if I keep it its going to get a transplant.
If numbers matching is the issue, pull it and wrap it in plastic for the next owner.
Old Dec 4, 2013 | 10:49 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Old Dec 4, 2013 | 11:27 AM
John485garage
Hi CaseyJones,
thanks for input. yes looked into intake up grade. Looks like Edelbrock #2101 is a direct replacement without modifling the hood. It also will take my rochester carb. I'll look into Lars. The exhaust is already a dual 2-1/2" back to mufflers, so that is done. Looks like there is room for headers, any suggestions on what to buy?
Old Dec 4, 2013 | 12:43 PM
John485garage
Originally Posted by jnealg
john,
Jnealg,
yes in a way your right. This car is in pretty good shape. Since it's the start of winter up here, the cars stored in my garage, I can get into a little upgrade and see if it will do the trick.
Old Dec 4, 2013 | 12:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...It's an ice cream car and don't plan on racing it, just cruising...
Tune it, leave it alone, and drive it. You don't need horsepower to go for ice cream.
Old Dec 4, 2013 | 01:15 PM
pacecar620's Avatar
pacecar620
Hello John485 and welcome to the forum. Good suggestion from Casey. That L48 is an excellent station wagon motor and will easily take close to 400hp. The Edelbrock Performer will save a bunch of pounds over that cast iron boat anchor manifold (if it's stock) and improve fuel distribution to boot. Plus the Edelbrock gives you the option of spread bore or square bore carbs and CFM choices from 390 to around 950, though 650 is a good all around choice for street. Ignition set to 36 degrees total @ 2800 to 3000 rpm, 180 thermostat and you should be good for cruise nights. No EFI and no computers - Whoopee!
Old Dec 4, 2013 | 01:52 PM
CaseyJones's Avatar
CaseyJones
After thinking about it, I would probably leave the stock exhaust manifolds on it. You won't be turning enough RPM's to really benefit much from headers unless you simply like the idea of having them plus the car will be quieter inside with the stockers. Personally, I install them IF I plan on additional modifications that needs them as part of a good foundation. True dual exhaust with decent mufflers is good enough for street use. I like Hooker Headers, but to each his own. They seem to fit well and are as durable as any others.
Old Dec 4, 2013 | 01:56 PM
John485garage
Hello pacecar620,
I got this vette from a women that parked it in her garage 8 years ago and forgot about it. So, after getting it to my garage, I went through it to see what it needs. I haven't driven it yet, brakes needed to be overhauled and other stuff done to get it in safe running order. Tank drained and fuel pump, carb. replaced. All liquids changed hand turned crank to make sure it wasn't frozen. New battery turned key fired it up. Runs great!! all original stock motor that I can tell, except the carb. and air cleaner. I will look into replacing the intake as some of the vette guy's said to do. Already went with 180 therostat, timing will be next, along with getting the correct air cleaner.
thanks
To 1975 L48 motor upgrades
