Rochester Carb Question
Old Dec 5, 2013 | 08:22 AM
1977C34ME's Avatar
1977C34ME
Default Rochester Carb Question
This likely seems like a pretty lame question to senior members and those in the know... but here goes.
What is the purpose of the canister that sits immediately forward of the throttle linkage at the carburetor on my 1977 350. It has a single wire running to it and looks like it gets actuated by the linkage.. or vice versa.
How do I determine if it is functional.
Thanks guys.
Old Dec 5, 2013 | 08:32 AM
TedH's Avatar
TedH
On my '80 L48, this device, an 'Idle Stop Solenoid', presses against the throttle blade when the A/C is running; to compensate for the drag on the engine.
On eBay for your '78 vette:
http://www.ebay.com/itm/Auto-Tune-A4...92d424&vxp=mtr
I stand corrected. Found the following comment on a BBS:
"It's an anti-dieseling solenoid not a idle control solenoid for the hvac.
Back in ancient times, retarded spark and lean air/fuel ratios to reduce emissions meant a lot of curb idle throttle opening to maintain idle speed. Problem was, when you'd shut the engine down, it would tend to "run-on" or "diesel". That solenoid exists to fully close the throttle plates upon shutdown. "
I've improved my timing and ignition and rarely if ever see this item activated on my '80 L48.
Old Dec 5, 2013 | 08:41 AM
1977C34ME's Avatar
1977C34ME
Excellent. That makes a lot of sense.
Thank you.
Old Dec 6, 2013 | 12:52 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Actually, the solenoid prevents dieseling. For proper idle speed on A/C cars, the carb's primaries have to be open too much which uncovers the transfer slots which allows fuel to be pulled into the induction system after the ignition is turned off, which often causes dieseling.
So in about 1971, GM took the ordinary idle adjustment out play and deployed this solenoid instead. The plunger is extended when the engine is running. When the ignition is shut off the plunger is quickly pulled back allowing the primaries to close completely preventing fuel from entering the hot combustion chambers. (Make sure the set screw for the idle speed at the throttle linkage is out of play).
You're also to adjust the idle speed using a 1/2 wrench on the hex of the plunger.
Old Dec 6, 2013 | 08:02 AM
gcusmano74's Avatar
gcusmano74
Once you have modified your distributor to operate on full time vacuum advance, the tendency for the engine to run-on is very much reduced.
Then, you can wire the solonoid to keep the idle speed up when the air conditioner compressor is engaged. (Not NCRS correct, but useful)
To Rochester Carb Question
