1968 Power Steering Add On
Old Dec 6, 2013 | 08:01 PM
twinpack's Avatar
twinpack
Default 1968 Power Steering Add On
I have a all manual car. I want to install factory components for power steering and use the power steering pump for Hydro boost brakes. Does anyone know if I need to be concerned with the hydraulic piston interfering with the stock oil pan on the sbc 327. Also can I use my manual relay rod or do I need a power steering relay rod. Any suggestions would be appreciated.
Thank you
Old Dec 7, 2013 | 10:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by twinpack
...Does anyone know if I need to be concerned with the hydraulic piston interfering with the stock oil pan on the sbc 327...
The stock power assisted steering will not interfere with the stock oil pan.
...Also can I use my manual relay rod or do I need a power steering relay rod...
You will need a relay rod with provision for mounting the power steering control valve and cylinder.
...Any suggestions would be appreciated...
Follow the diagrams in the 68 AIM optional power steering installation. That will get you factory power steering. I do not have a clue what that will do for Hydroboost.
Old Dec 7, 2013 | 11:36 AM
carriljc's Avatar
carriljc
Default I did this to my 68 years ago.....
BUT if I was doing today I would go for the Borgeson(SP?) conversion. You might want to look into that....it looks a lot simpler, cleaner, and less complicated.
Anyway, FYI:
I bought a kit and it came with a different relay rod, did not use the manual rod.
Old Dec 7, 2013 | 05:37 PM
twinpack's Avatar
twinpack
Thanks for the clarification
Old Dec 7, 2013 | 05:44 PM
twinpack's Avatar
twinpack
Anyway, FYI:
Will check it out
Old Dec 7, 2013 | 10:20 PM
carriljc's Avatar
carriljc
Default There's quite a few threads on that borgeson conversion...
...on this forum. It looks like the hot ticket to me.
To 1968 Power Steering Add On
