1981 Corvette - AT, 100% stock, 60K miles. I have been given the green light by the wife to order a new motor for Christmas!
I live in Alaska and I can only get 90 Octane on a regular basis at most gas stations. This a daily driver and I DO NOT want to mess with octane booster for daily driving.
The ZZ4 "recommends" 92 Octane and the 290 HP "recommends" 87 octane fuel. Any idea how serious this "recommendation" is?
Knowing that I will be able to run at best 90 Octane, will I have to retard the timing on the ZZ4 to keep the pinging down? And if so, will the retarding wind up lowering the HP to the point that I won't get enough difference over the 290 HP?
I suspect that I will still have some HP advantage with the ZZ4 even if I tune it down a bit, but at almost twice the cost I am worried that it won't amount to a hill of beans at the end of the day.
Do some of you guys that really know a lot about tuning motors have a guess as to how much I will loose if I have to tune down the ZZ4 a bit considering my fuel situation?
what are the cost of both engines ?consider a 383 sbc with dish or flat top pistons ,and add some large chamber 76cc aluminum heads .pick out the parts and figure out the static compression before buying any thing .then add a cam that makes the dynamic compression ratio safe for 90 octane .what do most snowmobiles up there run on ?
In the north you have to live below the year around snow line. Also the majority of paved roads are only near the coast where the majority of the states population lives. That is why they call it the frozen North!
Even where he said he lived in Anchorage (right on the Ocean that also freezes solid). Almost all roads are packed snow and ice through middle of May. Then by early June the plants turn it into a jungle because of nearly constant sun light. the snow maybe recedes up the mountains to about 2500 before it starts snowing again in the fall.
I didn't go measure 2500 feet, but I'm telling you stuff up north is snow capped year around.
I would suggest that everybody needs to put Alaska on their bucket list.
To the poster. California only sells 91 octane. I'm not sure why they think they need 92 octane because they are lower compression motors like 9.6 with aluminum heads
The new ZZ5 uses the fast burn head and usually you will find 32 degrees total advance to work well with that head..And 90 Octane should be plenty. I run 91 here in NY and never have any issues.
What are your priorities? Direct, drop-in replacement? 290hp engine is the ticket. Even if you plan to boost performance, it will satisfy with replacement parts (on your schedule) up to about 400hp. Beyond that, the ZZ4 would be the better platform to begin from.
The ZZ4 at 10:1 would *probably* be OK with a full advance curve and 90 octane...but it is right at the edge. I base that on a 10.2 engine I built that would not run full advance on 89 octane, but did fine on 92.
There are a lot of other crate choices between these two, including the 350 HO and many from other vendors that would live just fine on 90 octane.
The 290 is fine for a lo-po motor, but I wouldn't go into it expecting to build power on top of it. Cast crank, cast pistons and PM rods. I personally would not push more than 1 HP/CID through that combo. Keep in mind there are shotblocks available as well, that you can add exactly the cam and heads you want for your application.
I agree. Decide on the platform and performance goals and buy/build the solution. You will be happier with the end result. If I could install retro roller conversion parts from my engine in a ZZ4 short block, I would pull the trigger in an instant.
I would not buy any engine nowadays with a flat tappet cam. I think the base ZZ4 at 355 hp (without the fast burn heads) is the best buy out there. Alum heads and intake, forged (granted not 4340) crank, roller cam, 400+ ft lbs torque etc - but I'm running #93. I'd be careful running under what GMPP recommends. My .02 FWIW.
It sounds like the consensus is that the ZZ4 will probably work with 90 Octane although I might have to tune it down just a bit to play it safe. Warranty is a concern but I wonder if Chevy would actually ever check my fuel on the odd chance that I have a problem anyway.
I appreciate the advice about possibly going to 290 route and building up to something similar (in HP) to the ZZ4.
My current motor is just too weak to make the car fun to drive. If I could get 0-60 in 6 to 6 1/2 (never timed it but specs say stock motor is 8.1 seconds) I would be content for a daily driver. In my earlier days I had a 70 GTO that I went overboard on the HP and it became too much of a beast to run around town in. I want to avoid that on this one.
Knowing that I will probably never want to go above 355 HP (zz4) on this particular car. I am inclined to go with the 290 at half the cost. If it turns out to be too slow. I can build it up a bit to a respectable 330-350 without over doing it on the crank and block.
Just to satisfy my own curiosity, I looked up the specs of the zz4 cam, and ran the numbers through my DCR calculator, and I get a static compression ratio of 9.94:1, and a dynamic compression ratio of 7.99:1. I think that's cutting it a little close for 90 octane gasoline, especially since the .051" head gasket gives the engine a quench distance of .076", which is not exactly optimal.
I haven't bothered to run the numbers for the 290 HP engine, but just from looking at the specs, I would guess that you could probably run it on kerosene without any problems. It's DCR is probably less than 7:1.
The O/P aint spending the money on more then the 290hp .. I think he just needed some reassurances and he was talking octane to get himself to the 290 motor.
If you go the 290 route, you could probably bring it up to 330 HP or so with just a new set of heads. I'd wait at least until the warranty runs out. I think it's 12 months on the 290.
What the hp/torque rating on that. Like the fact that it comes with roller rockers. Fitment under the hood could be a problem especially with the med rise intakes like on the ZZ4. I had to go with a 2 1/2" air cleaner element (vs. the stock 3") on my ZZ4 to clear the hood - and it just made it.
