Tilt/Tele Steering Column
Old Jul 9, 2002 | 06:21 PM
vandome2's Avatar
vandome2
5th Gear
Default Tilt/Tele Steering Column
I've purchased a tilt/tele steering column and plan on swapping my unit (regular) for it. Need to change colors (has anyone re-fininshed a steering column? Has anyone changed out a regular steering column for a tilt/steering column for a 72 Convertible?
[Modified by vandome2, 10:22 PM 7/9/2002]
Old Jul 9, 2002 | 07:38 PM
trw's Avatar
trw
Default Re: Tilt/Tele Steering Column (vandome2)
The refinish is fairly straight forword. Just prep and paint.
The tilts were interchangable from 69-75. Bolt in and plug in.
Terry
Old Jul 9, 2002 | 07:42 PM
vandome2's Avatar
vandome2
5th Gear
Default Re: Tilt/Tele Steering Column (trw)
What do you use to strip the column?
Old Jul 9, 2002 | 09:18 PM
gearheadz's Avatar
gearheadz
I used a combo of spray stripper & wire wheel to take the majority of the column housing down to bare metal. Since I tore down & rebuilt it entirely, I used stripper on the parts that I could completely separate & wire wheel for other areas. I then primed it with a few of coats of sandable auto primer (sanded in between coats) then used a couiple of coats of Rustoleum semi-gloss black for the top coat. It came out beautiful!
Mark
To Tilt/Tele Steering Column
