Cover under diff/strut rod
Old Dec 11, 2013 | 02:33 PM
VetteNURSE's Avatar
VetteNURSE
Default Cover under diff/strut rod
Can anyone tell me what the sheet metal cover is called that goes under the dfff near inner strut rod mount on a 76. I am trying to get a new one but the vendors cant find it. I am not sure of the name or how to order it.
Thanks,
Mike
Old Dec 11, 2013 | 02:40 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I believe it's a heat shield. Have you checked the AIM?
bashcraft's Avatar
bashcraft
Maybe because it's not supposed to be there?
Old Dec 11, 2013 | 03:29 PM
rponfick's Avatar
rponfick
Do you have a fiberglass spring? That may explain your problem.
Ralph
Old Dec 11, 2013 | 04:04 PM
kanvasman's Avatar
kanvasman
It is supposed to be there, I think. at least I have the same thing on my '78 and didn't think it was supposed to be there either. It looked like it was some type of skid plate under the differential. Haven't gotten around to putting things back together yet, so not sure what to do with it.
Old Dec 11, 2013 | 04:17 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by bashcraft
...Maybe because it's not supposed to be there?...
Some model years with the cat con have the heat shields. My 80 has one and additional shields on the front Y pipe. I specifically made the AIM reference because if the 76s had the shield, the AIM will show it and list the old, original part number for it. That being said, I don't know whether they are being reproduced.
Old Dec 11, 2013 | 05:06 PM
mds3013's Avatar
mds3013
It is a heat shield for the stock rear "Y" pipe. If you have this type of exhaust then you could use it. If there are no pipes in this area it is not needed.
The part number in the '77 AIM is 356918. Rear crossover pipe shield. mike...
http://www.ebay.com/itm/Corvette-Original-Rear-Differential-Crossover-Exhaust-Pipe-Heat-Shield-1975-1977-/200991397589?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ecc0556d5&vxp=mtr
To Cover under diff/strut rod
