Tempsender to LS3
There's a brass plug threaded into the drivers side of the block. Remove it, drill out the center, tap it reuse your sender. IIRC mine was 1/2" NPT on my 68.
The ECM uses the LS sender in the drivers side head.
1) Drill out the pass cyl head and tap it to fit the old school sender
2) Turn down an old school sender and cut threads on it to match the metric head
3) Use an aftermarket sender with metric adapter
http://www.summitracing.com/parts/ATM-2277/
http://www.speedwaymotors.com/Auto-M...pter,8195.html
4) Remote mount the sender. Drill/tap the WP, weld a threaded bung onto a short length of 1.75" pipe and splice it in the radiator hose, use an adapter to mount it on the radiator etc
Here are a number of hose splicers - http://www.jagsthatrun.com/Cooling-S...rts_Order.html
Rick B.
