Help me identify this ignition shielding
Old Jul 9, 2002 | 09:46 PM
Mailcop's Avatar
Mailcop
Default Help me identify this ignition shielding
Digging around in the basement again and found this distributor cover/ignition shielding. It's a two-piece unit and appears brand new. Still has remnants of GM labels inside, but no part numbers. I recall being told it was for a 71, but I'm pretty sure it's not. Anybody recognize what year this fits and approximately what it's worth? Thanks in advance.
[Modified by Mailcop, 1:59 AM 7/10/2002]
[Modified by Mailcop, 2:00 AM 7/10/2002]
Old Jul 9, 2002 | 10:20 PM
rainman69's Avatar
rainman69
Default Re: Help me identify this ignition shielding (Mailcop)
It is the exact same as my shielding for a '69.
Old Jul 9, 2002 | 11:38 PM
kostutsman's Avatar
kostutsman
Default Re: Help me identify this ignition shielding (rainman69)
If it fits a 69 it would also fit a 68 - if this is true I am looking for a full set - looks like you have the top half - would you take $40 for it?
kos
Old Jul 10, 2002 | 12:50 AM
John D.'s Avatar
John D.
I am not sure what year its is but I have a 1971 with it missing and could use one if it is for a 1971.
Old Jul 10, 2002 | 11:52 AM
Mailcop's Avatar
Mailcop
Thanks for the responses.
Looks then like this must be a 68-70E part. I recall that it did not fit a 71 I owned.
Old Jul 10, 2002 | 11:55 AM
GDaina's Avatar
GDaina
68-69, both years used same shield, but one side is broken. Both sides should be spot welded. The one side, the sides have broken from the weld.
[Modified by GDaina, 10:59 AM 7/10/2002]
To Help me identify this ignition shielding
