HELP!? MY MECHANIC SCARED ME!!!
Old Jul 9, 2002 | 11:16 PM
Justin79-L-82's Avatar
Justin79-L-82
Default HELP!? MY MECHANIC SCARED ME!!!
I just took my car to the mechanic and dropped it off to get the cam and intake installed. He asked me a few questions that got me thinking about the whole thing. What is the difference between the L-82 cam, and my xe262 comp cam? Is there a significant difference. Also when the engine is apart we were going to do a compression test then get a valve job on the heads. He is also fixing alot of other little things (hoses, seals on the engine etc) Is there else i should tell the mechanic, or anything i should be worried about?!
Old Jul 10, 2002 | 12:02 AM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: HELP!? MY MECHANIC SCARED ME!!! (Justin79-L-82)
From Comp Cams website - XE262
Gross Lift - .464 intake .470 exhaust
Duration @ .050 lift - 218 intake 224 exhaust
LSA 114
L82 cam (from GM parts website)
Gross Lift - .460 intake .450 exhaust
Duration @ .050 lift - 222 intake 222 exhaust
LSA 114
Not a whole bunch of difference, IMO.
AC
Old Jul 10, 2002 | 12:22 AM
Justin79-L-82
Default Re: HELP!? MY MECHANIC SCARED ME!!! (A C)
Is it even worth changing the camshaft if i'm putting a new intake and headers on? Since there is not that big of a difference between the two?
Old Jul 10, 2002 | 12:51 AM
bigvette1's Avatar
bigvette1
Other than installing a fresh valve train (cam, push rods, guides, rockers) and like you said maybe a valve job, not much gain from the cam swap. If you do all including the intake etc. there should be a good difference. However, you need to weigh the cost of the project. I would go to a Comp 268 and the manifold. Get others comments also.
Old Jul 10, 2002 | 12:55 AM
Stevo81's Avatar
Stevo81
"anything else I should be worried about?"......money? :yesnod:
Old Jul 10, 2002 | 01:03 AM
Darkness's Avatar
Darkness
Default Re: HELP!? MY MECHANIC SCARED ME!!! (Stevo)
See if you can change it fo the 268
Old Jul 10, 2002 | 01:05 AM
Justin79-L-82
Wellll... i already have the weiand intake and xe262 cam here and at the shop so i guess i'll put it in :rolleyes: see how it works out... if it doesn't make much of a difference then hey.. i guess i wasted a grand in parts :lol: plus the labour. oh well
Old Jul 10, 2002 | 01:14 AM
Shark Racer's Avatar
Shark Racer
The 78 engineering specs put the L82 as .450/.460.
I think the XE262 would have a slightly broader power band, and would be a marginally better cam. Improvements would be more noticeable w/ a better flowing system.
Since you're pulling the heads, you may as well do the cam. Cheap, and it'll freshen up the valves. With the headwork, headers, and intake, you might expect an extra 5-10 hp over the L-82 cam. Probably more torque as well.
-Steve
Old Jul 10, 2002 | 01:54 AM
Justin79-L-82
Default Re: HELP!? MY MECHANIC SCARED ME!!! (Pacin'California)
WHat would the difference be between the xe268 to the l-82 cam, as opossed to the xe262? WOuld that also be very marginal?
Old Jul 10, 2002 | 01:56 AM
Shark Racer
Expect a marginal increase from the XE268 over the XE262, another 5-10 hp. But CHP reccommends the XE262 for a daily driven car. Gets better mileage and more lowend.
-Steve
Old Jul 10, 2002 | 02:01 AM
Justin79-L-82
So I didn't necessarly make the wrong choice for the cam.. fhew..... that takes a load off. thanks
Old Jul 10, 2002 | 02:20 AM
Taijutsu's Avatar
Taijutsu
I try not to get involved in cam talk. In this case I have the same cam specs. I have CC 218-224 HR. W/1.6 RRs I get .529 in .539 ex. If you are going spend this kind of time/money then change to HR. The TFS heads and Air Gap w/750 Demon vs is very daily drivable. The cam is listed for the limit of stk converter. I have M21 w/3:55s so it doesn't matter. My ONLY complaint is I need a 5th gear! I seldom go above 3500 rpm. At that point things are happening fast! Also your 79 had single ex and cat you will need dual pattern cam. To see the real benifit of changes, ex will need to be improved. This combo is very smooth and easy to drive fast. The next bigger cam would be nice w/mods.
Old Jul 10, 2002 | 02:43 AM
Shark Racer
Default Re: HELP!? MY MECHANIC SCARED ME!!! (Taijutsu)
HR will cost you a pretty penny, whether you have the block machined or use retrofit lifters. I am going to run HR on mine, but only because I am certifiably insane, and don't have any plans to put money into my 'vette's engine after the "planned" modifications are done. HR are definitely better performance, better economy, and better longevity, but are you willing to spend roughly $600 more?
-Steve
[Modified by Pacin'California, 10:44 PM 7/9/2002]
Old Jul 10, 2002 | 11:47 AM
john's '81 mouse's Avatar
john's '81 mouse
Ask your mechanic about performing a back cut on valves and seats, maybe even doing a 'three angle' valve job as long as you have the heads apart. (Doing this should improve low valve lift flow) If your mechanic doesn't know what a three angle valve job is, suggest you find a new mechanic.
Old Jul 10, 2002 | 01:05 PM
Justin79-L-82
Default Re: HELP!? MY MECHANIC SCARED ME!!! (john's '81 mouse)
The mechanic is doing a three angle valve job... Since i'm taking alot of stock parts off and replacing them (exhuast manifold, intake, airbox etc) is there any market for them? Do you think i could sell them on e-bay or or something or are the not worth anything?
Old Jul 10, 2002 | 02:12 PM
BTRNSEX's Avatar
BTRNSEX
I suggest you keep all your old working parts. Someone is always looking.
Not saying this will happen to you.....but I have seen people get valve jobs and blow there rings on a worn motor. Just something to think about. Sorry can't help on the cam stuff....totally clueless here.
Good Luck
Old Jul 10, 2002 | 03:27 PM
Matt Gruber's Avatar
Matt Gruber
when someone says
HELP MY MECHANIC SCARED ME
my first thought is that he pulled down his pants! :lol:
xe262 good for +50-75 hp, pants up. :jester
To HELP!? MY MECHANIC SCARED ME!!!
Old Jul 10, 2002 | 05:43 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
If you are running an automatic, a stock torque converter and a stock rearend, the XE262 is a better choice than the XE268. The XE268's torque and hp come on at higher rpms than the XE262. You'll have more lowend torque with the XE262 and have a much more streetable car.
PS
Replace your valve springs!
[Modified by Smokehouse69, 3:44 PM 7/10/2002]
Old Jul 10, 2002 | 05:55 PM
Taijutsu's Avatar
Taijutsu
Default Re: HELP!? MY MECHANIC SCARED ME!!! (Smokehouse69)
Lot's of good advice so far. Making power is only part of the deal. Carefully match the power curve to trans and rear gear. Take your time and do your homework! You will be much happier in the long run. The waek link will break first.
Old Jul 11, 2002 | 12:57 AM
Justin79-L-82
Well.. i knew the 262 cam was a good choice.. but later on after i get my headers and exhaust installed i was thinging of getting a shift kit, torque converter and new rear gears... what are your thoughts on that... would it still be a good combo?
