Is it normal?
Old Dec 16, 2013 | 09:49 PM
Sayfoo's Avatar
Sayfoo
Default Is it normal?
My 69 427/390 with Hooker side mount headers and pipes. Identical hardware on each side.
At idle, they sound different. Drivers side is a steady rythem and passenger side is more eratic and uneven.
Is this because of the fireing order being biased towards one cyl bank?
Or unbalanced carb?
Old Dec 16, 2013 | 10:11 PM
pltmgr's Avatar
pltmgr
1968 NOM BB hooker headers/sidepipes. Mine sound the same.
Old Dec 16, 2013 | 10:20 PM
Sayfoo's Avatar
Sayfoo
I looked up the firing order and it looks to me that the firing sequence is the same, just out of phase, so mayb the carb idle setting?
Old Dec 16, 2013 | 11:12 PM
1Fordman's Avatar
1Fordman
One day my son drove the 68 (bb 435) and I was a passenger. Noticed the right side sounded a bit different then the left side.
Did not sound rough and uneven, just a bit different. Maybe just my hearing, after all I'm an old timing man! (Borrowed from Cheech and Chong)
Old Dec 17, 2013 | 09:43 PM
Sayfoo's Avatar
Sayfoo
Sounds like it might be normal, for whatever reason, but I'd be interested to know why.
Any engineer types out there?
Old Dec 18, 2013 | 01:55 PM
1977L48's Avatar
1977L48
my 77 L48 sounds the same, like a pop/clomp from the passengers side, while drivers side has an even tone, if you think of the firing order, 1-8-4-3-6-5-7-2, its drivers, pass, pass, drivers, pass, driver, driver, pass, the only thing i can figure is that its firing more on the pass side than then drivers in a row, so you hear the individual fires on the drivers side and with the long tube headers it puts two of the same side cylinders firing so close together that it comes out almost like one noise. but thats just a shot in the dark
To Is it normal?
