Dynomax headers with TFS angled plug heads?
Old Jul 10, 2002 | 08:32 AM
Fevre's Avatar
Fevre
Default Dynomax headers with TFS angled plug heads?
Anyone running Dynomax headers with Trick Flow angled plug aluminum heads? Any problems with plug wire routing? Just want to make sure before I order them.
Old Jul 10, 2002 | 11:40 AM
Woodstoc's Avatar
Woodstoc
Default Re: Dynomax headers with TFS angled plug heads? (Fevre)
Godd luck with getting them. I started trying to get them in late May and they are still on backorder..... :mad
I will run them with Sportsman II angle plugs. I have been told there are no issues.
Old Jul 10, 2002 | 11:44 AM
gdh's Avatar
gdh
Default Re: Dynomax headers with TFS angled plug heads? (Woodstoc)
That is interesting about the World heads because they said that they would not fit with my Dart heads.
Old Jul 10, 2002 | 12:05 PM
Fevre's Avatar
Fevre
Check the summit web site. I see no b/o (backorder) icon showing for the vette headers. I have not called but they are pretty good about showing that icon if the stuff is on backorder.
Old Jul 10, 2002 | 11:45 PM
glen242's Avatar
glen242
That's what I'm running. No problems when running the wires over the valve covers.
Old Jul 11, 2002 | 02:40 AM
thebruce's Avatar
thebruce
I've got the TFS 23 deg heads with angle plugs, and Dynomax headers-- no problems with fit. I have the plug wires running underneath right now, but plan on running them over the top when I get around to getting new wires.
Old Jul 11, 2002 | 06:52 AM
Fevre's Avatar
Fevre
Default Re: Dynomax headers with TFS angled plug heads? (thebruce)
That what I wanted to hear! Although I did not call to check, you sometimes will hear one thing from a tech department but another from real world users.
Thanks, I will be ordering them with my 10% discount by Aug 1st.
Forgot to ask which boots you are using, 90 or 180 degree. I am guessing 90 but will 180 work? Gonno order another set of the summit brand, was very happy with them but burnt one on my exhuast manifold.
[Modified by Fevre, 4:57 AM 7/11/2002]
Old Jul 11, 2002 | 03:27 PM
Chucks76's Avatar
Chucks76
That is my setup too. Also run them over the valve covers....with 90 degree boots.
Old Jul 11, 2002 | 03:28 PM
Fevre's Avatar
Fevre
Default Re: Dynomax headers with TFS angled plug heads? (Chucks76)
:cool: I have a set of wire looms already in service.
To Dynomax headers with TFS angled plug heads?
