Anyone using lock washers on their header bolts?
Old Dec 22, 2013 | 12:07 PM
Scottd's Avatar
Scottd
Default Anyone using lock washers on their header bolts?
Noticed that my header bolts were loose, AGAIN. Short of fancy locking systems or drilling and wiring my existing bolts, is there a better way? Im assuming the simple solution is to use a split type lock washer? (This is going on a Heddman header) This may be a simple solution that Ive missed in the past?
Old Dec 22, 2013 | 12:13 PM
1977L48's Avatar
1977L48
im running them on my 427 in my Monte Carlo, they stay tight.
Old Dec 22, 2013 | 12:25 PM
C3 Stroker's Avatar
C3 Stroker
Header bolts loosen by the compressing of the header gaskets, making way for space. I always re-tightened them after about a week's driving and they are good to go. No further problems after that. If you still have problems, Stage 8 makes a good set of locking bolts.
Old Dec 22, 2013 | 12:30 PM
chvet73's Avatar
chvet73
There are several good locking bolts available for headers. They all work well. Standard lock washers will not do the job unless you like constant retightning.
Old Dec 22, 2013 | 01:03 PM
Scottd's Avatar
Scottd
Cant be any worse than what Im already dealing with. My headers are a leaky mess, Im running double paper gaskets on both sides. The Metal ones just dont seal like I need them too. Guess I may investigate the locking bolts, but for now Im going to try a cheap .07 cent lock washer.
Old Dec 22, 2013 | 01:16 PM
7t9l82's Avatar
7t9l82
Old Dec 22, 2013 | 01:19 PM
cv67's Avatar
cv67
St. Jude Donor '05
Fortunately never had that issue use the small head stainless arps/alum heads. Antiseize no washer, regular ol Fel Pro (1404?)
"just" snug them down on new gaskets get it warm in the garage, let it cool then snug them just a bit more.
Old Dec 22, 2013 | 01:41 PM
1977L48's Avatar
1977L48
i also use VHT paint on my gaskets, spray them very heavy on both sides then install them and tighten, run the engine for a few days, then re-tighten, the paint works like a sealer also, never have had one fail
Old Dec 22, 2013 | 01:43 PM
Street Rat's Avatar
Street Rat
I use loctite blue.
Old Dec 22, 2013 | 03:07 PM
75sl48's Avatar
75sl48
I'm fighting leaky headers also. I got the Percy aluminum gasket and smeared copper rtv on around the ports. Still got a small leak on the driver side. I even put a slice in the flange so the headers would sit flush
Old Dec 22, 2013 | 03:19 PM
TimAT's Avatar
TimAT
The only way I've ever found to keep the bolts tight is maintenance. Install and then tighten them every heat cool cycle for the first couple of weeks, then once a week, then just keep checking them. Between the gaskets compressing, the different expansion rates between the head and the header, if you don't stay after them they leak.
Old Dec 22, 2013 | 03:46 PM
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
I just use a stainless steel Allen head bolt with a split ring lock washer.... Aluminum gaskets ...double checked them 4 years ago ....doing fine!
Old Dec 22, 2013 | 05:34 PM
diehrd's Avatar
diehrd
If your headers have a thin flange this could be the reason. Also after initial install drive it for 15 minutes and let it cool off and re-torque .. That should be all you need to do except once and a while check them but the should be ok for a long time.
Old Dec 22, 2013 | 06:25 PM
Scottd's Avatar
Scottd
Well, I double gasketed them and torqued them down as tight as I dare go. I think in the past I may have been a little light handed on them seeing how they are just little 7/16th bolts. Ill be keeping an eye on them. My driver side was BAD for a while. All 4 plugs were covered in soot and you can see in the old gasket where the exhaust was blowing out.
Old Dec 22, 2013 | 06:26 PM
diehrd's Avatar
diehrd
Why a double gasket ? Are your surfaces not flat ? I think the double gasket is more likely to leak then a good single gsaket
Old Dec 22, 2013 | 06:32 PM
1977L48's Avatar
1977L48
true, you are exposing more surface area of the gasket to the exhaust heat and pressure
Old Dec 22, 2013 | 08:13 PM
jcuprisi's Avatar
jcuprisi
If you're interested here is a site about fasteners:
http://www.boltscience.com/index.htm
They explain why lock washers don't work.
To Anyone using lock washers on their header bolts?
Old Dec 22, 2013 | 09:16 PM
carriljc's Avatar
carriljc
Default Do yourself a favor and buy the locking bolts....
I used to struggle with this until I bought the Stage-8 kit. I have the Stage-8 locking bolts and I haven't had to mess with my headers since I last installed them about 9 or 10 years ago.
If I was to do it today I would get these guys instead:
http://www.jegs.com/p/Percys/Percys-...42129/10002/-1
The Stage-8 bolts work great ( as you can tell by the time period I mention) but they are PAIN to install and lock down. The ones in the link are easier to work with.
Old Dec 22, 2013 | 09:58 PM
75sl48's Avatar
75sl48
Those look like a 12 point head tho. I know on mine I cannot get a socket on all of the bolts.
Old Dec 23, 2013 | 08:15 AM
spikebot 81's Avatar
spikebot 81
I used allen head bolts and split style lock washers. Anti seize on the bolts and retorque after 1 heat cycle. No problems and no leaks
I guess every engine is different. I had a ford truck with hooker supercomp headers and for the life of me never was able to keep the header bolts tight. Even thought about bashing the bolt threads to keep the buggers in place.
