Engine Rebuild or Swap
Old Dec 23, 2013 | 01:03 PM
RushThruLife's Avatar
RushThruLife
Originally Posted by diehrd
I am a big believer in the ZZ series GM motors because you are getting completely new factory fresh motor.. Look at the zz383 .. But get it with out the intake unless your willing to change the stock hood.
I have been looking at these also. But not being so mechanically inclined, Im not sure exactly what I need
Old Dec 23, 2013 | 01:09 PM
TedH's Avatar
TedH
Originally Posted by RushThruLife
Heads and cam were done proper to my purchase. If I were to guess. I would have to say she's putting down somewhere around 325 at the rear wheels. The car will burn rubber out of a hole shot in 1st and chirp into second(auto tranny)
I get that performance with 225rwhp/290rwtq. The low-end torque is what gets you the tire smokin' performance off the line.
Old Dec 23, 2013 | 01:53 PM
billla's Avatar
billla
St. Jude Donor '14
I'd take that number with a big grain of salt.
IMHO, first step would be to pull the valve cover and find out exactly what you have for heads. Then spend $300 on a good chassis dyno tune and see where you're at.
Old Dec 23, 2013 | 02:11 PM
CUSTOM 80's Avatar
CUSTOM 80
3rd Gear
I have a AN L82 BLOCK (4 BOLT MAINS)/ 1970 LT1 HEADS ENGINE WITH 61K MILES bORED BALANCED BLUEPRINTED, HEADS ARE FULLY RACE PORTED WITH A 510 LIFT RETRO ROLLER SETUP.. THE MACHINIST JIM RHEA IN MARYLAND SAID THIS IS EASILY A 440 HP MOTOR WILLING TO SELL IT
Old Dec 25, 2013 | 01:23 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Yes 350hp at the wheels can be almost 475hp gross. Thats quite a build for even an experienced builder. Requires good heads, big cam, high compression, stroker crankshaft. Since GM doesnt sell a small block that powerful u would need a engine builder with good reputation. Golan engines and TPIS are 2 that I can think of but not for tight budgets. They have been in business making and selling performance sb chevys for decades.
Good luck,
cardo0
Old Dec 25, 2013 | 02:52 AM
bluedawg's Avatar
bluedawg
Check our cnc-motorsports. Good products good prices, you get what your paying for, goid folks.
Old Dec 25, 2013 | 08:18 AM
fishslayer143's Avatar
fishslayer143
When it comes to performance engines, Horsepower =Money spent .. If you want power ,its gonna cost. If you want alot of power, is gonna cost a lot. Theres no way around that... But ,. the end usually justifies the means, the big smile on your face, the first time you turn it loose..well, that's priceless!!
Old Dec 25, 2013 | 11:20 AM
CanadaGrant's Avatar
CanadaGrant
I run a ZZ4 crate motor in my wifes 78. It has the stock intake and stock 58cc aluminum heads and I use the stock hood. To get a bit more power I went with the GM hot cam and 1.6 rockers. For the extra cost I could have/should have just gone with the 383... Pretty well everything just bolted right up with no surprises.
Old Dec 25, 2013 | 11:36 AM
diehrd's Avatar
diehrd
I bought my 80 with a fresh ZZ4,, So I went with the complete ZZ430 clone set up on her and it never lets me down power wise or dependability ...
Old Dec 25, 2013 | 07:31 PM
cardo0's Avatar
cardo0
our cnc motorsports?? your in alaska and cnc motorsports is in south dakota. Who the heck are u working for???
Old Dec 27, 2013 | 10:00 AM
RushThruLife
Originally Posted by cardo0
Dont know the condition of your L82 Rush but the L82 is a great base motor easily capable of 350hp with just good heads (that will provide compression increase also) and good tune. Well headers would help some also but not necessary for 350hp.
How many miles on eng? Any problems?
IMHO if your less than 200k mi just go for the heads and tune. Heck even paying a shop to install heads would be cheaper than 350hp crate.
FYI the L82 comes with performance cam, forged pistons and forged crankshaft. If your seals are leaky then just get them replaced. Dont make it harder and more expensive than it needs to be.
Hope this helps,
cardo0
This is a short of what I know my L-82 has
RHS pro actionheads,180 intake port. Holly carb
Comp Cam xe 262 extreme energy, 462 intake lift and 469 exhaust lift.
1.6 comp cams roller tip rocker arms
Bowtie overdrive transmission 2004r stage 2
Hedman Headers
