Front crossmember
Old Dec 23, 2013 | 12:56 PM
Bigeddie's Avatar
Bigeddie
Default Front crossmember
guys earlier this year i got my lower control arm on drivers side fixed. it was seperating from chassis or the front crossmember. todayi had to get my crossmember fixed and ended up paying another amount of money to fix another tear. check your chassis andget it reenforced its better to do it now where you can shop around and find someone knowledgable and and able to do the job right.that and its dangerous if you dont know whats going on down there in the chassis..here a few pics sad day especially since i am broke and have been trying to save to install a t56.
Old Dec 24, 2013 | 12:37 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Thanks for the pics and info.
Old Dec 25, 2013 | 11:20 AM
WESCH's Avatar
WESCH
Hi
This kind of cracks can be reduced by using a spreader bar.
It eliminates front crossmember flexing and avoids this cracks.
Rgds. Günther
Old Dec 25, 2013 | 12:19 PM
garygnu's Avatar
garygnu
scary ! when I rebuild my cars I plan on adding some extra steel on the front cross member .
Old Dec 25, 2013 | 01:48 PM
TCracingCA's Avatar
TCracingCA
Default What kind of handling are you generating????
My car will pull about 1.3g! Thus I rewelded and gusseted the crap out of the car. I am putting the rollcage back in with chromoly being in the process of replacing the old steel also! And the guy above with the speader bar was a wise suggestion!
Even on a stock Corvette, I think they should be rewelded in those locations. They all will crack!!!!!!!!!!! Usually why guys can't get the suspensions to align.
Old Dec 25, 2013 | 03:56 PM
Bigeddie's Avatar
Bigeddie
exactly from what i heard chevy didnt do a "complete"weld throughout the chassis.its a stock vette but it has been twice i had to go to a shop for emergency welding two costly mistakes that i hope people will avoid my putting gussets and finishing weld on the chassis and that spreader bar might be something i will do.
Old Dec 25, 2013 | 09:37 PM
75sl48's Avatar
75sl48
What's a spreader bar?
Old Dec 26, 2013 | 03:20 AM
WESCH's Avatar
WESCH
Hi
It's a adjustable bar that is bolted between the upper A-Arm attachments and keeps the curved front crossmember from flexing.
If a original mechanical cooling fan is used, it might be difficult to install it, but is is possible. All part vendors offer this. VB&P for sure does.
They offer 2 types, once a prewelded bar, only fits if no mechanical fan is there , then a unwelded one that can be positioned in the car for best location and then welded.
Both are finally only bolted on between the A-Frames.
Cost around 100 USD, nothing for the safety it provides.
Rgds. Günther
Old Dec 26, 2013 | 10:26 AM
75sl48's Avatar
75sl48
So basically a strut tower bar
Old Dec 26, 2013 | 10:40 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
In a way. Strut tower bars typically limit the flex from the spring towers as found in unibody cars. A spreader bar actually uses both sides of the frame as reinforcing points to limit frame flex. It does not tie the frame to the body as a tower bar tends to do, giving a three point brace.
Old Dec 26, 2013 | 01:52 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Zip sells a front crossmember repair:http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={bc5617d7-1d48-41a4-bdc0-864b11e00518}&gid={2ecd0d3a-0b6f-4f3e-bead-078294fd7fde}&GroupName=Frame+Crossmembe rs&pname=63-82+Frame+%231+Front+Crossmember+Repair&R eferer=&Alias=&ptct=SGR-SR&CTitle=&.
Though out of stock they post they can ship by 12-27-13.
Hope this helps,
cardo0
Old Dec 27, 2013 | 03:41 AM
WESCH's Avatar
WESCH
Hi
It's probably a hell of a job to replace this repair metal sheet because the A-Arms need to be disconnected and I believe it even goes around the spring pouches.
I'm planning on replacing it on my 68 due to corrosion and heavily bend due to jacking , but will leave this till a frame off resto latest in 5 Years.
A professional weld repair should also take care of this crack.
Rgds. Günther
Old Dec 27, 2013 | 03:49 AM
TCracingCA's Avatar
TCracingCA
Default You won't be able to buy this particular one in a store!
Because I made it! This is what we are basically talking about. A number of Suspension parts guys sell kits!
I moved this from one of my older posts in another thread where this stuff came up in conversation awhile back!
"""A big block really can benefit from a spreader bar, but you would have to engineer that in on a big block. Fitting one on a big block car is more difficult than a small block. Thus some guys actually cross brace the frame at points below where a spreader bar mounts.
This is when I was running solid uppers, how I had my spreader bar engineered, before switching to the SPC's"""
To Front crossmember
