hood release knob
Old Dec 26, 2013 | 11:38 AM
donaldbly's Avatar
donaldbly
Default hood release ****
My hood release **** on my 82 has slack in the cable causing the tube that the cable runs through to hang up on bracket when pulled out. How do I adjust slack out of cable so that handle doesn't travel out so far.
Old Dec 26, 2013 | 11:47 AM
nspctr01's Avatar
nspctr01
I'm new to this but working on the same assembly currently. There is a "lock nut" if you will a the end of the cable near the latch. IIRC you can unscrew the nut and move upwards on cable to remove slack.
I'm sure others will chime in if I'm misinforming you.
Old Dec 26, 2013 | 11:39 PM
don hall's Avatar
don hall
Originally Posted by nspctr01
..... There is a "lock nut" at the end of the cable near the latch......you can unscrew the nut and move upwards on cable to remove slack.
As suggested.... adjustment is at the latch end...... use the barrel nut to reduce slack:
Old Dec 27, 2013 | 10:20 AM
donaldbly's Avatar
donaldbly
thanks for the info
Old Dec 27, 2013 | 10:21 AM
donaldbly's Avatar
donaldbly
Thanks!!!!
Old Dec 27, 2013 | 10:24 AM
GreenDream's Avatar
GreenDream
And while in the process of adjustment, inspect the cable for any fraying or worn sections. If it doesn't look good, replace it. When you pull that hood release and it ends up in your hand, you have a real issue getting you hood open. Don't ask how I know. On my 81, I installed a separate short cable on each side and hid them down in the cowl as a backup release in case it ever happened again.
Old Dec 27, 2013 | 10:57 AM
donaldbly's Avatar
donaldbly
I would have never on thought of that...good advice Thanks!!
Old Dec 27, 2013 | 10:15 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Went to adjust mine and the cable was so frayed in had two strands of the cable left, just replaced it with aftermarket one.
To hood release knob
