replacing heads..
Old Dec 30, 2013 | 10:46 AM
scottyp99's Avatar
scottyp99
Originally Posted by petemonster
The 268H is a good mild street cam but ,since you will be getting new heads they will come with better springs so the more aggressive 286H will have a better lift to duration ratio for the combo.It will allow you to take advantage of the new compression on the bottom end while opening up the top end a bit.
Oh, my! That's a pretty big cam. The only experience I have with a cam that big was in a 440 cid engine, back in the late '80/early '90s (292 cam in a 440 Roadrunner) It had a 3.55 diff gear, and a Torqueflite 727 with a torque converter from a 6 cylinder car (that was an old trick, even back then) It ran well on the street, because of the extra cubes, but I would think that in a 350 cid engine, you would need a bit of gear and converter to make it work well.
Scott
