Hi!
Long time since I've been around the forum. Life has kept me very busy and the vette parked for long periods. Sad, but there's no intention of ever selling my baby so she can rest easy.
My wife bought me a killer Christmas gift this year... FAST XFI 2.0 fully sequential fuel injection conversion kit. Today I started digging in to the 383 and pulled off the Edelbrock performer RPM intake. The ports on the stock cast heads match up fairly well with the old intake... but the ports on the EFI intake are much larger. Measurements as follows:
Heads
1.14" X 1.97"
New intake
1.24 X 2.28
I'd like to do my best at port matching and also do some polishing of the runners of the new intake. These measurements threw me for a loop today. What do I do in this situation to ensure proper airflow without removing the heads? What do I do for gaskets? The old setup had Fel-Pro 90314-1 gaskets.
you could try some epoxy in the intake ports of the new intake ,and use a dremel to port it to match the head port .use the intake gasket you had on the head for a template .
This is easy. Tell the wife you have to have some new heads to match up with the 383 and intake. They are well matched but the stock heads are a mismatch. No problem!
She figured me out long ago.. I could probably justify the new heads - but I worry about the repercussions. "honey, my bracelet broke. You know that nice diamond one I like?".
Gary, thanks for the idea, but I would just assume weld it to add material. Not too keen on the idea of epoxy in the runners.
Sigh... New intake or new heads...
I don't know that you can get up the runners far enough welding to make the taper from the plenum to head gradual. You may have to pull the heads and port them to match the intake. If you do port the stock heads, watch out at the pushrod pinch point. It is easy to go through there. Back in the old days when 461, 462, and 292 iron heads were the heads to have, we ported them to big intakes quite often. Porting cast iron is no fun though and I don't care to have to ever do it again.
I think myself, I would wait until I could replace the heads to put the new manifold on. It would be much more rewarding in power output to go along with the great FI drivability!
Bolt it on as is with the gasket the intake requires. You won't lose much. Your better off going bigger to smaller than the other way. The ledge is tiny. your talking 1/10th of an inch /2 and 3/10 of an inch / 2. No big deal. I have done a square port intake on oval port heads with a lot more difference than this with no perceived issues.
That's what I'm beginning to think.. Problem is, I have no idea where to start with all the options out there. I guess first step is to get my cam specs... Motor paperwork has been MIA for a while now.
Don't radius the head, and don't waste time polishing the intake runners.
I guess it can't hurt... New heads can always be on my Christmas list next year!
