Should I get a Spreader bar?
This bar can be a life saver as it reduces crossbar flex and age cracking near the A-arm attachments caused by this.
A must only for that reason already, not to talk about handling improvements being a nice side benefit.
It can be made to fit at every C3 if the unweld version is used . Sometimes requires a bit of engineering, but still an easy install.
Happy new year. Günther
With that said, as mrvette noted correctly, the more modified the suspension, the more benefit, but considering the frame flex in any unmodified C3, a spreader bar will benefit ALL C3's, and NOT insignificantly.
On my 78, I have a 100% stock type suspension with the Speedirect spreader bar (no C4 suspension, coil overs, etc) BUT have taken great pains to eliminate as much suspension rubber deflection as possible-poly upper and lower control arm bushings, poly front shock bushings on the Bilsteins, poly sway bar mounting and endlink bushings on the 1 1/8 inch front bar, custom blue printed/rebuilt OEM steering box by GTR1999, poly bushing on the power steering cylinder, poly mounting bushings on the OEM type 3/4 inch rear swaybar, poly bushings on the 360 composite spring, competition adjustable strut rods with NO bushings (heim joint ends) AND 255/45/17 ZR ultra high performance summer only tires. The car rides MUCH better than the stock gymkhana suspension with 255/60/15 junk tires and handles/steers like a modern sports car. It's that good. Is it as good as my 2010 Z06 or 2012 Lexus IS350 F Sport? NO but it is a VERY different car than what rolled off the assembly line in October 1977 when the car was built. The spreader bar IMCO should be on every C3, modified or not, since for the money the benefits are real. Hope that helps!
http://www.corvetteactioncenter.com/...r-in-a-C3.html
AND it is most obvious that the biggest thing you can do to improve handling is a lower profile, WIDE tire.....gotta start with the basics.....
"You may need to lift the frame slightly so the cross shafts do not try to slide off the studs. After installation pre-load the spreader bar slightly outwards."
Keep ya posted.
I have the VB&P one for the 75 that is already welded together, but it has an electric fan and no air. The one for the 80 was the one you have to weld together. I don't think a welded one would have worked.
Hope that helps!
