Tire sizes???
Old Jul 10, 2002 | 11:57 PM
Corvettelvr73's Avatar
Corvettelvr73
Default Tire sizes???
What size tires are you guys runnin on the front and rear with the stock 15" rims?
Old Jul 11, 2002 | 12:06 AM
Corey_68's Avatar
Corey_68
Default Re: Tire sizes??? (Corvettelvr73)
Most are running 255X60X15's on the rear. I'm running those on all 4 corners.
Old Jul 11, 2002 | 12:25 AM
rainman69's Avatar
rainman69
Yup, 255/60VR15 here. :cheers:
Old Jul 11, 2002 | 12:52 AM
BobJ's Avatar
BobJ
Oh good, someone else brought this up so I won't have to (any of you Sr. members getting tired of answering "the tire question"?) :smash:
I'll probably slap some new sneakers on my '70 within 6-months. It's got the 15x8 rally wheels. I want to go raised white letters, they weren't OEM were they? Leaning towards BFG because I've had negative "longevity" with Eagles in the past. Any thoughts on this?
Where's the cheapest place to buy them online, I've got a tire machine in my shop.
Old Jul 11, 2002 | 01:54 AM
Corey_68's Avatar
Corey_68
I purchased my 255X60's Firestone Firehawk's at http://www.tirerack.com
:cheers:
Old Jul 11, 2002 | 02:54 AM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Tire sizes??? (Corey 68)
The Kellys have worn well on mine.
Old Jul 11, 2002 | 05:26 AM
MILO851's Avatar
MILO851
295 50 15 back
255 60 15 front
Old Jul 11, 2002 | 07:34 AM
Sleper's Avatar
Sleper
I have removed my parking brake assembly and love the fat meats. Here is a answer to a question I asked Vette Magazine:
Jon,
There's only one possible problem area with the 275/60s. They're the
perfect size tires for the stock 8-inch wheels and there is not clearance
problem around the fenders. The trailing arms present the potential problem,
and this seems to differ from car to car. Actually, the only point where
there's any possible clearance issue on the stock trailing arms is the
parking brake cable bracket, which is factory-welded onto the outer side of
each arm--just about where the sidewall of the tire is. We're running an
article on this very subject in the July issue, and used my '76 for the
guinea pig. In a nutshell, the solution (to insure you don't have any
problems) is to relocate the parking brake cable bracket onto the top of the
trailing arm. The parking brake still is fully functional, and getting the
bracket out of the way gives an extra inch or so of clearance for tires.
I'll be running a picture of a '72 Vette that's running 295/50-15s (on stock
rims) on the rear, with the modified original trailing arms. It's tight with
the 295s, but even those thing do clear. I put 275/60s on the back of my '76
and they fit perfectly. Feel free to call me if you have any specific
questions.
Bob Wallace
Editor, VETTE Magazine
Old Jul 11, 2002 | 09:18 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
225/70R15 all around for me
Old Jul 11, 2002 | 09:30 AM
1LE's Avatar
1LE
255-60-15' BFG Rrdial T A's front and rear. No problems with rubbing
Old Jul 11, 2002 | 03:33 PM
groovyjay's Avatar
groovyjay
With stock rims I used to run 255/60/15 all around. Now I got something "bit" different. :yesnod:
Old Jul 11, 2002 | 04:20 PM
jvm's Avatar
jvm
Default Re: Tire sizes??? (Sleper)
Pleasem excuse this question from a newbie. If some of you guys are running extra wide tires, don't you get more rock chips on your body?
Paint jobs aren't cheap. Jim
To Tire sizes???
