Outside Air Valve...I think???
Additionally what HVAC control position should cause this flapper to move?
Trying to determine if the HVAC vacuum control switch is working or not.
I actually got this flapper out....not sure how I am going to get it back in though???!!!
This vacuum pod is operated by the green stripe hose that is on the number 5 position of the select valve. The diagram below shows you the operation of this valve in different positions.
Wombvette is correct about issues.. Leaves, glue, and then the nipple on the flapper door being broke (the vacuum hoses connect to both sides as a pass thru).
Willcox
I have the same diagram as above in the manual and thought the same that it was supposed to be the MAX AC position. However putting the HVAC control in MAX AC did not do anything. Pulled the actuator out, applied vacuum and it does operate so the actuator is good....so must be the vacuum control in the HVAC is no longer working.
Appears that I will need to replace this part of the switch.
Also seems like I will need to do some trimming as there is no way that the flap would ever close as is. The flap was wedged in tight with no room to move.
Just something else to fix...although I do not have the AC compressor installed....its sitting in a box on a shelf.
Thanks for the help guys.
Go to the kick panel and see if that pod is working before you do anything. The orange stripe hose is on the same nipple.
I check all the vacuum actuators by applying vacuum to each of the hoses and watched the actuator moved with the exception of the one that controls coolant into the heater core.
There are five hoses going to the vacuum switch, one is source and then four to actuators. However there are five actuators. I am assuming the black with white stripe splits to two actuators: one for the outside air valve and the other for the coolant flow control to the heater core. I still need to check the coolant control for movement, all others work fine.
Going to try the drop of oil on the vacuum switch.
Thanks for the hint.
