Ok what pushrods do i need?
Old Jul 11, 2002 | 08:58 AM
emsrescu's Avatar
emsrescu
Default Ok what pushrods do i need?
I am going with the edelbrock proformer rpm kit. Heads, cam, lifters, timing chain and gears. it says to use hardened 5/16 push rods. And may need to use ones that are .100 longer. How do i measure to see if i will need to use the longer ones or can i just use them anyway? I have proform roller rockers and hydrolic lifters. :smash:
Old Jul 11, 2002 | 11:15 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Ok what pushrods do i need? (emsrescu)
You can purchase an adjustable pushrod to check for correct geometry to get the right length, try summit, jegs.....
Old Jul 11, 2002 | 09:41 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
The instructions for my RPM heads called for .100 longer than stock pushrods so I just put in .100 longer than stock ones. Haven't had any problems with them. They're available in many brands Jegs, Summit, and others carry them.
To Ok what pushrods do i need?
