Coil under ignition cover
Old Jan 7, 2014 | 01:17 AM
patriotcommercial's Avatar
patriotcommercial
Default Coil under ignition cover
I am putting together a big block 1973. The coil looks like the top will be to close to the underside of the ignition cover. Can someone give me a detailed measurement from the bottom of the coil to the top of the Bakelite where the wire plugs in. I think my replacement coil may be to tall. Also, how close to the manifold should the bottom be, I have it sitting about 3/8 up in the bracket.
Old Jan 7, 2014 | 05:37 PM
kjbuster1's Avatar
kjbuster1
Default Coil measurements
My '72 BB coil is about 1/2 off the manifold and about 4 7/8 inches tall from base to base of terminal.
Old Jan 8, 2014 | 12:18 AM
patriotcommercial
Thank you for the help
To Coil under ignition cover
