Throttle Cable Bracket
Old Jan 10, 2014 | 10:17 PM
nspctr01's Avatar
nspctr01
Default Throttle Cable Bracket
Putting back together the 81 I bought and preparing to install the throttle cable bracket. The motor is a L48 and not the stock motor.
Does the bracket sit flat on the intake or does it mount differently? The intake is new and has a ridge that comes across and directly under the bracket. This causes the bracket to not sit flush. Want to make sure I'm mounting it correctly before I grind the bracket down to fit over the ridge.
Old Jan 10, 2014 | 10:36 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
If you could fab an adapter out of a piece of sheetmetal that would fit under your throttle bracket to keep it from "rocking"on the ridge (or buy one from a hardware store), you'd have extra support.
It would not need the holes shown in the photo....you would drill the hole(s) that you need.
Old Jan 10, 2014 | 11:20 PM
nspctr01's Avatar
nspctr01
So, If I am reading this correctly, bend a piece or two of sturdy metal in a C shape just high enough to clear the ridge and mount the bracket to adapter/adapters.
Right. How hard would it be to access the intake bolts to tighten them down? Wonder if you could cut a piece of "strap" thats used in electrical work to mount electric panels etc?
Old Jan 11, 2014 | 01:15 AM
doorgunner's Avatar
doorgunner
I don't have a mental picture of the intake/ridge...so I'm just guessing about what might work.
Maybe if the strap was heavy-duty---it would be great if all the needed holes lined up.
Old Jan 11, 2014 | 08:49 AM
nspctr01's Avatar
nspctr01
Problem I see is the misalignment of the cables and how to get the intake bolts in and out? Will raising the bracket/cables that far interfere w/ something else? I have some strap, I will cut a piece and see what it does..
Old Jan 11, 2014 | 08:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Are you using an aftermarket intake manifold?
Old Jan 11, 2014 | 08:58 AM
doorgunner's Avatar
doorgunner
A photo of the problem would help a lot....I might be leading you in the wrong direction. The cables cannot be too high.
Old Jan 11, 2014 | 10:42 AM
nspctr01's Avatar
nspctr01
Yea, it's a aftermarket intake. I will try and get a pic up
To Throttle Cable Bracket
