Sprung door spring
Old Jan 12, 2014 | 02:59 PM
kcarlasc's Avatar
kcarlasc
Default Sprung door spring
So finally got around to putting the drivers door spring back in after it popped out.
Problem is.. I can get it back I super easy.. But when I close the door it just pops back out....
Is the spring just bent or not usable or is my hinge hosed.. I don't see anything wrong with the hinge but hard to see the underneath.
Thanks in advance...
Old Jan 12, 2014 | 03:19 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
That's because it's not in completely. Did the same thing with mine, you will notice the notch in the spring, it has to fit just right into the slot, in order not let it pop up when you close the door. Can't temember exactly what I did, but just look at your directions again. I doubt if your spring or hinge is "hosed"........
Old Jan 12, 2014 | 03:23 PM
CanadaGrant's Avatar
CanadaGrant
Once you get it back in you have to tap it back up into position with a hammer. Willcox has a video on this.
http://willcoxcorvette.com/product_i...ducts_id=27616
Old Jan 12, 2014 | 06:57 PM
kcarlasc's Avatar
kcarlasc
I watched the video.. But did not have to use a hammer.. In fact I was able to do it with my finger. That's why I wonder if the spring it out f shape.. Looks ok, but who knows
Old Jan 12, 2014 | 07:15 PM
havesometo's Avatar
havesometo
I had the same problem with mine popping out. If you look under the door hinge where the spring goes the hole became sloped so the spring slid out very easy. I took a washer and cut it in half and tack weld it. Check and see if thats your problem.
To Sprung door spring
