Quick question with a simple yes/no answer?
Old Jul 11, 2002 | 08:21 PM
Binnie77's Avatar
Binnie77
Default Quick question with a simple yes/no answer?
Were there any '77 L82's built with a TH350 auto tranny? Any documentation I have says no but I had in my garage today an original L82 with its original owner and it has a TH350 tranny so whats the scoop???
Old Jul 11, 2002 | 08:43 PM
Larry B.'s Avatar
Larry B.
Default Re: Quick question with a simple yes/no answer? (Binnie77)
There were 6,148 L82's made. The auto transmission option (M40) cost an additional $146 with the L82. The M21 4 speed required the L82 option and 2,060 were sold. That would leave the remaining L82's as automatics.
[Modified by silvervetteman, 7:45 PM 7/11/2002]
Old Jul 11, 2002 | 08:47 PM
corvettemaster's Avatar
corvettemaster
Just checked in the BB, and it confirmed that the 350 tranny was available at an additional $146
[Modified by corvettemaster, 7:49 PM 7/11/2002]
Old Jul 11, 2002 | 09:05 PM
Binnie77's Avatar
Binnie77
Default Re: Quick question with a simple yes/no answer? (corvettemaster)
I noticed that too but was that not for the 400 tranny?
Old Jul 11, 2002 | 09:31 PM
bob's Avatar
bob
Default Re: Quick question with a simple yes/no answer? (silvervetteman)
There would have also been L-82's with M20's
bob
Old Jul 11, 2002 | 09:36 PM
page62's Avatar
page62
I don't think your answer is being questioned: you want to know if what ratio of TH400 vs. TH350 trannys were installed in '77. I don't know the answer, but knowing GM I would guess more than a few! At the time, they had a habit of grabbing whatever was available and sticking it in the car. That's why there are a few L48's with 4-bolt mains... :smash:
Old Jul 11, 2002 | 09:57 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
mine has th350. i dont know what else they would come with...
[edit] M20 apperntly. :D
[Modified by '79ProwlerOrange, 7:01 PM 7/11/2002]
Old Jul 11, 2002 | 10:07 PM
Larry B.'s Avatar
Larry B.
Default Re: Quick question with a simple yes/no answer? ('79ProwlerOrange)
TH350 was the only automatic available. TH 400's stopped in 75. Borg Warner Super T10 was also used but no M-20's
Old Jul 11, 2002 | 10:35 PM
bob's Avatar
bob
Just looked through my GM Data from GM Canada -- 77 Corvette
L-48 and L-82 could have RPO M20 which is a wide ratio BW
L-82 only could have RPO M21 which is a close ratio BW
L-48 auto was a 350 with a 2.52 low gear
L-82 auto was a 400 with a 2.48 low gear
The 350 in the L-82 must have been one of the assembley line swaps. It should also have had a drive shaft with a centre length of 29.81 inches instead of the standard L-82 shaft which is 29.50 inches.
Old Jul 12, 2002 | 12:00 AM
tangee-vette's Avatar
tangee-vette
Default Re: Quick question with a simple yes/no answer? (bob)
I quick grab to keep the production line moving does seem logical.
Old Jul 12, 2002 | 12:01 AM
tnt76vette's Avatar
tnt76vette
Must beg to differ with you Silvervetteman. My very early '76 has the TH-400 for sure......maybe I got the last one? :cheers: :cheers: :cheers:
Old Jul 12, 2002 | 06:40 AM
Larry B.'s Avatar
Larry B.
Default Re: Quick question with a simple yes/no answer? (tnt76vette)
OK ....lighten up :lol: :lol: I know there were mixed 350/400 transmissions between 75-77. Low performance engines of the era and cost were the main reasons GM switched to the TH350.. A friend of mine has an L82 77 that had a TH350. It seems that I remember reading somewhere that 75 was the last year for TH400's. That is a good question for the NCRS board. Manufacurer's do running changes, books are wrong, ( the 69 assembly manual shows an LT-1) I try to give the best answer I can and like everyone, Sometimes I get it wrong. Sorry...
Old Jul 12, 2002 | 09:06 AM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
As I recall, my late '76 L-48 had a TH-400. I could be wrong, but I believe that's what it had.
Old Jul 12, 2002 | 09:23 AM
VettePower's Avatar
VettePower
Your bothwrong because my 77 L82 has a TH400. Mine must be the last one. Wow now I can sell it on Ebay as extremely rare TH400!!! Last one manufactured!!! :D
Old Jul 12, 2002 | 09:53 AM
Binnie77's Avatar
Binnie77
Well I guess this isn't a simple question after all. All of the documentation that I have from NCRS states that there were no L82's in '77 with the TH350. From '78 to '81 the TH350 was used exclusively according to their documenation.
Old Jul 12, 2002 | 10:20 AM
Fevre's Avatar
Fevre
This is very :cool: info. Now I can just take me car as is to any NCRS show and say well that was what came on the car, prove me wrong! Then referred to stuff like this. :lol:
Old Jul 12, 2002 | 06:37 PM
Larry B.'s Avatar
Larry B.
Default Re: Quick question with a simple yes/no answer? (Fevre)
That's the fun part of this hobby... Researching and comparing. Even the NCRS guru's are not always in agreement. New stuff turns up all of the time. That is why well documented Corvettes are so sought after. A tank sticker or build sheet can enhance the value of your car and settle many unanswered questions. G/M's record keeping in the U.S. was very poor and they really weren't concerned about the owners 25 or 30 years later. They just wanted to go home after the day's work like we do.
[Modified by silvervetteman, 5:37 PM 7/12/2002]
To Quick question with a simple yes/no answer?
Old Jul 12, 2002 | 08:50 PM
paso's Avatar
paso
The "package" I received from GM Canada On both my 76 and my early build 77 shows on the back page under two colums headed by Turbo Hydra-matic
that the torque converter outside diameters were different with the L48 option vs the L82 as well as the stall ratio were differant. It also lists the front and rear bands on the L82 option were "circular steel with organic lining" the planetary gear ratios show 2.52:1 vs 2.48:1 as noted above. so there appears to be diferences. Anyone with george zappora's info can check it out on the back page. a quick look thru the registry linked below may also show something.:)
Old Jul 13, 2002 | 03:57 AM
Stevo81's Avatar
Stevo81
As you can see with 20 posts, here on the forum there are no quick questions or simple answers. Simple folks, maybe. oops :lol:
Old Jul 13, 2002 | 04:08 AM
rainman69's Avatar
rainman69
Default Re: Quick question with a simple yes/no answer? (Stevo)
And then the bastard clutch child chimes in...
I've got a '69 with original engine and transmission (L46 M20). I did a clutch replacement a few months ago and discovered the following:
Correct 14" flywheel bellhousing
"Correct" 14" flywheel, drilled for a 10.4" clutch (instead of the 11" clutch).
Now, if it were an early '69, I could see the small clutch/flywheel combo, due to it being used in the L46 from '68. But in '69, GM went to the larger diameter for the L46...
I guess they just didn't have any 11" clutches when my car was assembled...By the way, the clutch/pressure plate assembly and flywheel were the original factory installed parts.
