Shock recommendation for Drag racing
Old Jan 16, 2014 | 09:09 AM
jaybird81's Avatar
jaybird81
Default Shock recommendation for Drag racing
I have an 81 4sp and a built up 350. I am planning on replacing the shock and was wondering what type you would recommend. I plan on Drag racing the car. Any recommendations would be appreciated. Thank you.
Old Jan 16, 2014 | 09:15 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
QA-1 adjustables on the rear..set real stiff. Much stronger rear spring.....90/10's on the front.
I've got a set of Moroso front springs also that help get things moving.
Works for me.
JIM
Old Jan 16, 2014 | 09:29 AM
jaybird81's Avatar
jaybird81
Works for me.
JIM
Jim,
Thanks for the quick response. What 90/10's in the front do you recommend?
Old Jan 16, 2014 | 10:45 AM
gkull's Avatar
gkull
Jim mentioned heavy rear spring. I would start with a 420# mono spring like from VB&P. Another item is the rear "Smart Struts" The control camber gain during rear suspension compression. Get the metal ends or at least the poly
Old Jan 16, 2014 | 10:49 AM
SpartyGW's Avatar
SpartyGW
Koni adjustables in the front. I used to race in Pro class in my 67 Camaro, 9 second quarter mile NA, full weight car.
EDIT: sorry, after looking for a part # for you, the only Koni shock I could find for an 81 @ Jegs was not really a drag shock. I _can_ tell you that the Competition Engineering shock is crap. There is a Lakewood shock that is straight up 90/10 for the 81 (Lakewood 40101) but I can't speak to it's efficacy.
Old Jan 16, 2014 | 11:31 AM
jaybird81's Avatar
jaybird81
Thanks for all the advice. I looked at the Lakewood 90/10 as well. This car will be far from a 9 second car, so I am not even sure how much shocks will effect ET. Probably looking at the 13 sec range.
Old Jan 16, 2014 | 12:54 PM
Ibanez540r's Avatar
Ibanez540r
I wouldn't worry about a drag racing set-up then. Go to the track, and hit the gas.
Old Jan 16, 2014 | 05:23 PM
427Hotrod's Avatar
427Hotrod
If you do the Mono spring... shocks will be critical. I had a custom made 460 LB one on mine and it was a bouncing fool. Never knew what lane it was going to come down in! They nicknamed me Flipper for a while as it porpoised around.
Seriously, I do know some drag folks that had good luck with the glass springs...they just had better shocks than I had at the time. Probably could have made it work, but I switched to a custom made 6 leaf from Vette Brakes (Daytona 5 leaf with an added main leaf) and the QA-1's and it was instant straight line after that. Heavy....but works perfectly.
I've heard folks say Moroso springs go weak...but mine are still fine. Santhruff seems to be the rage these days. Also...I have Competition Engineering 90/10's and they've done fine....but as the car has become faster they are probably due for an upgrade with a little more control.
As mentioned, a Smart Strut kit will keep the camber change correct.
But as mentioned..at the 13 second level you won't need much. Vette's hook like crazy with the right tire. A set of 90/10's on the front will make a big difference in how it launches if you have initial issues.
JIM
Old Jan 16, 2014 | 08:25 PM
SpartyGW's Avatar
SpartyGW
LOL! Yeah sure! It always starts like that. Before you know it you want to run 12s. Then you put a cage in it and blink your eyes and you're chasing 10s.
Have fun, bro, the track is a great place to really enjoy your car.
Old Jan 17, 2014 | 07:00 AM
Lt1er's Avatar
Lt1er
JIM
Us little 400 or so HP 355 ci 4 speed Vettes don't have all the problems that high HP big ci motored have. The 420# rear mono and the Koni adjustable set on stiff. You adjust the rear spring bolts to get a level car. I even have the 9/16th rear sway and Smart Stuts. I don't have 90/10 or front skinny tires.
All that works together and my vette launches straight. My only draw back is 3.55 rear gears. with drag radials and a small burn out i have slip the clutch out of the hole. It is pretty close to dumping the clutch.
At the lights I bring the rpm to right on 2500 rpm. At our local drag strip I get 12.90's. I like the Fast Friday night test and tunes over the higher pressure long lines at NHRA bracket racing
Old Jan 17, 2014 | 09:06 AM
427Hotrod's Avatar
427Hotrod
No doubt it gets tougher as you add stupid power. I ran mine with the 427 for years with a set of VB 550 lb front springs, the 460 LB rear spring and stock shocks and a VB Smart Strut kit. Big front tires and sway bars intact. It launched hard and straight. It was running low 11's at the time and that was just because I was launching softly to save rear end parts. Hard launches broke stuff. It had power for a high 10 sec pass. (trapped 123+ MPH). The point is that it takes very little to make one hook....Vette's have always been great "street racers" due to huge engine setback and weight transfer.
When I stuck the 90/10's on it the first time I was able to come out harder and slip the clutch a little more as I rode the fine line between bogging and spinning. When I had pure street tires on it the 70/30 setting worked real well.
Here's a shot on plain BFG street tires..suckers are actually wrinkling!
Here's what traction does...
JIM
Old Jan 17, 2014 | 01:32 PM
Solid LT1's Avatar
Solid LT1
I think I have a brand new set of 90/10's around my shop somewhere, any one want them $100 for the pair I think they are 3 way adjustable 70/30, 80/20 and 90/10 clicks on them as I recall.
Old Jan 17, 2014 | 04:02 PM
BKbroiler's Avatar
BKbroiler
If you're running 13s, as opposed to 9s and 10s, you don't need much suspension work. I've been thru the 13s and down to low 12s now with old stock front shocks, sway bar in place, stock replacement 9 leaf rear spring, new 50/50 rear shocks and 275/60/15 drag radials, BFGs. My best 60ft is 1.69 with consistent 1.73 - 1.75 times, with no wheelspin and plenty of weight transfer. (Auto trans.) See below.
To Shock recommendation for Drag racing
